I'm attempting to convert video from my new Sony MicroMV camcorder to DVD compliant MPG format. I was successful in using Xmuxer to convert the .MMV files (MPG TS) into standard .MPG format, however these files have a bitrate of 12mbps CBR, which is too high for DVD.
Next, I tried to convert them using TMPGEnc to 7mbps VBR. The conversion ran successfully, however the resulting video has some artifacts that were not present in the source file.
In particular, the video appears to "skip" every 1/2 second or so. This is most apparent on panning shots, the motion is not fluid, every 1/2 second the picture jumps.
I checked the field order as well as all the other settings. Everything appears to be correct.
Any ideas of what could be causing this problem are appreciated.
Thanks,
Tomasz
Results 1 to 1 of 1
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 16:22 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
