when you strip the vob files on the stripping screen on the right hand side there are 3 choices...1 GB...650 Meg and No split..what are theses for?
650 MB is for if you wanna do miniDVD/cDVD www.vcdhelp.com/minidvd.htm would I assume.
1 GB is if you have one huge vob(joined several vobs) that you are going to burn on dvd, the dvdstandard requires max 1 GB vobs. -
ok heres the thing...i have 6 vob files unstripped at round 5.5 gigs...I ran the stripper application and only chose to keep 1 english track. i chose the 1 gb setting in the stripper app. When it was done stripping I had 6 new vob files at 1 gig a piece. I opend them and they were only the one english track. any idea y they are so big?? i though stripping them would reduce the size of the vobs? i need to burn all 6 on a dvdr...
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 05:12 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
