i didn't find a guide how to convert a vcd .dat file to an avi file.
i have tried vcdcutter but it can only converts to .mpg
i also rename the .dat file to .avi but this works only on 1 vcd
i own. on my other discs it doesn't work. why ? why this works
sometimes and sometimes not ? is there a tool i can use to
convert them all ? please help.
.dat is mpeg
.dat is used on VCD's -- it's got a little more information in the file header - but it's essentially a mpeg
look for guides on how to convert MPEG to AVI
you can also get VCDGear to strip the extra info off the .dat header and make it a true mpegyour pal,
Stinky
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58
