Is this a good drive to buy in order to copy DVD's and is 1x on a DVD the same as 1x on a CD? because that would take forever to burn a 5 gig dvd at 1x CD-ROM speed?
If this is not the best DVD-R or RW to get can someone please tell me what is and what price I should be looking for.
thanks
Results 1 to 9 of 9
yeah its a good Drive. And No, 1x DVD burning isn't the same as 1x CD... To burn a full disk it takes 1 hour at 1x and 30mins at 2x.. its very quick.
I have copied dvds, but am having some trouble with audio sync.......... but yes its very doable. -
Do you mean a 'simply' copy like disc-to-disc CD copy?
No authoring required ?
Is a DVD R a true 4.7 GB 1,073,000 bytes a gig or 1,000,000 bytes a gig
Thank you
<font size=-1>[ This Message was edited by: VerbatimDVD on 2001-08-03 11:00:33 ]</font> -
4,700,000,000 bytes
websa is right about the burn times.
You can only do a "copy" if it's 4.7 gig or less. A lot of movies are now dual layer and have more than 4.7 gig. Those have to be reauthored after either: 1) re-encoding to a lower bitrate, or 2) editing the material into two or more discs.
There will be DVD+RW drives on the market later this year, Oct/Nov. I couldn't wait, so I'm enjoying my Pioneer DVR-A03 now. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
This will work if the DVD is the same as your blank. 4.7gb, single layer.
The DVD-R isn't exactly 4.7GB, I think they use the same 1000mb = 1GB as hard drive makers. But you can fit ~2 hours of mpeg2 video @ 5000kbit/s.
Or ~6 hours of VCD quality video.
And DVD-R will play on ALL DVD players that were made after 2000. Some of the older players may not accept the dics. But according to Pioneer, all newer stand alone players will play them. -
The lack of dual layer recordable DVD is starting to bug me a little, and I don't even own a recordable DVD drive yet.
I ripped Cast Away this morning so I could start to compress to VCD. I copied just the video and the 5.1 main audio track. Without the DTS soundtrack, English 2.0, French 2.0, English, Spanish and French subtitles, the movie still took up just over 6 gigs of space. -
Yes if possible?
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Questions about capturing video in PIONEER LX60
By kuba99 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Jun 2009, 04:48 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Questions about Pioneer DV-400 - Urgent...
By depeche101_Brazil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th May 2008, 23:21
