good morning.
I have taken a lot of vcd movies and slip them in 1/2 using TMPGenc, but I have tried numerous times to split a SVCD movie ( mpg ) with TMPGenc, and each time I do, TMPgenc just shuts down.
Am I doing something wrong ? or am I using the wrong program ?
Thanks much ,
Cheryl-Anne.
Results 1 to 9 of 9
Hi there,
are you sure that TMPGEnc shuts down?
It can take a lot of time to split a movie in Mpge2 format.
I have an Athlon 1.4 Gigaherz, and splitting a SVCD can take 5 minutes. So if TMPGEnc "hangs", just let it be for a few minutes, and then return. Maybe your movie has been split by then.The Dutchman -
Hi Dutchman,
When I attempt to "edit" the SVCD mpg it will then just come up with an error, - the program shuts down and does an "illegal activity" .
So you are saying this is not normal, huh ?
Gee, I hope I can figure it out, thank you for your help
C-A. -
How are you trying to split in tmpg? The "merge and cut" sucks for splitting but works great for merging. I always use the "source range" for splitting and have never had any problems
Hi again
I looked all over TMPGenc for the option you describe, but cannot find it
I need help
thank you in advance,
Cheryl-Anne. -
Hi Cheryl
click on file
click mpeg tools
click advanced
now put a check in the box by "source range"
now double click "sorce range"
from here you can cut your vid by using start and end points -
Its possible the trial period is over for the mpeg2 use (encode & edit). Also it sometime helps to hit the play button and let the stream play for a few seconds before trying to edit. I find that I have to manually enter in the end times as selecting it on the slide bar will not work for me on mpeg 2
Hi again
I lost you, I click on mpeg tools, but I do NOT see
an "advanced" button anywhereI'm using TMPGenc 2.52 I think it is,
I checked everywhere, and don't see "advanced" ok call me a dumb blonde now
Cheryl-Anne.
click on file
click mpeg tools
click advanced
from here you can cut your vid by using start and end points[/quote] -
Sorry Cheyl my mistake it is
settings
advanced
put check in "source range"
double click"source range"
and from there cut using start and stop points
My mistake
Computer shuts down
By shaolin2006 in forum ComputerReplies: 16Last Post: 18th Nov 2011, 23:15 -
PC Auto shuts down
By anfield7 in forum ComputerReplies: 2Last Post: 18th Feb 2010, 04:02 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
MIRc shuts down
By DuBsTaR in forum ComputerReplies: 2Last Post: 22nd Oct 2007, 14:23 -
Monitor shuts down
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 1st Oct 2007, 19:00
