  1. On Tuesday, VCDEasy was working fine.
    On Wednesday, VCDEasy didnt want to cooperate. For some reason, It didnt want to burn onto the cdrw. I kept getting a "writing data failed error" after hours of failures, I used a differenent brand of cdrw and it worked fine. It was the memorex brand that wouldnt write, BUT they worked fine before yesterday without any problems.
    Also, it has been popping out the disc in the middle of the burn process and says "failure to reload" ????? I have no idea why, but it only happens occaisionally. thank god I stopped using CDR's if it werent for RW's I'd be broke.
    Has anyone had this happen before?
  2. I had problems burning with VCDEasy after I updated Roxio's DirectCD. It appeared to start writing on the disk in the wrong place (too far away from the center), and so it would only fit ~650Mb on the disk. I reinstalled VCDEasy and the ASPI drivers, and then it started working again. You can use the "simulate" mode to troubleshoot, so there's no need to do any actual burning. I've never seen the failure to reload error.
