Results 1 to 10 of 10
  1. Hey when I try and use TMPC is says movie format not supported and at vcdhelp it said u need to add DIVX Codecs to the movie well how do u do it thanx.
  2. Download the relevant codec, install it - job done. The codec has to be on your PC and is not actually part of the movie file.
    Best bet to solve codec problems is download the Nimo Codec pack from the tools section and install this.
  3. Ok but I don't kno how to install the Codec is the Nimo Codec pack easier to install?
  4. just download, double click the .exe and follow the on screen instructions.
  5. Hey how do u install a Codec with Nimo Codec pack
  6. Do you actually know how to switch a computer on?
    Aug 2001
    Västerås, Sweden
    just download the file and dubbelclick it.
    if you cant start the installer, how did you ever manage to to post.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  8. Yes I can and there is a folder not a installer file
    Aug 2001
    Västerås, Sweden
    i dl the Nimo50Build7.exe and its as much a installer it can be.
    http://nimo.everwicked.com/Nimo50Build7.exe
