  1. Hi guys,
    I have rendered some video files as mpeg2 format, as in 1 .mpg file.
    Now to author them DVD i need 2 seperate streams the .mp2 and .mpa files.
    Is there an easy way to split the .mpg file or should i render as separate streams?
  2. Try using TMPGEnc's MPEG tools to demultiplex.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
