TLDR: This is not about Streamlink in general. It's about Titus-AU's plugins.
As recently as August 9th, 2026, I was able to download DRM-protected videos by using Titus-AU's Streamlink plugins. They can be found here: https://github.com/titus-au?tab=repositories. However, when I try to download a video now, I just get this error:I have tried this both on Streamlink 8.4.0, which worked in August, and the latest Streamlink 8.6.2. Here's an example Streamlink command. It's for the free Chicago-area PBS station that should be accessible by anyone in the US.[cli][error] No data returned from streamI even tried emailing Titus himself about this issue, but got no reply.Code:streamlink --plugin-dir C:\Users\James\Documents\Python\Streamlink --url hlsdrm://https://wttwdt.lls.pbs.org/lls/wttwdt/wttwdt-hls-drm/hls-drm.m3u8 --hlsdrm-decryption-key 002d9abb3d1814bf530d984cbe4a5721 --default-stream best --player-external-http --player-external-http-interface 127.0.0.1 --player-external-http-port 8080 --ffmpeg-fout "mpegts"
streamlink-plugin-dashdrm..METHOD=SAMPLE-AES
I'm not using the dash drm plugin. If you look at the command, you can see that the URL is prefixed with hlsdrm://. Therefore, it should be able to decrypt SAMPLE-AES just fine.
it worked fine with me tho
[Attachment 94142 - Click to enlarge]
here is a sample of the downloaded video
https://storage.to/59YY0ba16 -
Do you think PBS could be blocking my IP, because of abuse? That's the only explanation I can think of. I've tried restarting my PC, and it didn't help.
im not sure about pbs limits but sending too many requests can definitely get your ip temporarily rate limited or flagged
try restarting your router to get a new ip or just test it using a mobile hotspot or vpn if it starts working on a new ip then pbs definitely blocked your original one
use debug flag to see http req/res logs
Code:--loglevel debug
DoStudio has stopped working - help!
By TenementLady in forum Authoring (Blu-ray)Replies: 49Last Post: 11th Aug 2026, 07:43 -
Has 3D Youtube downloader stopped working for anyone else?
By adrian44 in forum Video Streaming DownloadingReplies: 27Last Post: 28th Jan 2025, 13:18 -
Get_iplayer has stopped working
By Gameshow Host in forum Video Streaming DownloadingReplies: 1Last Post: 28th Sep 2024, 08:45 -
aacgain has stopped working
By DarrellS in forum AudioReplies: 6Last Post: 1st Sep 2023, 12:23 -
EME logger stopped working
By hgfdgfui in forum Video Streaming DownloadingReplies: 6Last Post: 31st May 2023, 03:31
