Hi all,
After lot of frustration I'm writing this with a hope to get help from you all.
I'm having Ulead Video Studio 6.0 which is my first Video Editing software.
I was using this since March 2002.
Problem:
First time when I created the VCD with it was ok audio was in sync and fine. But from past 15 days I'm facing the annoying audio sync problem. The audio doesn't sync with lip movements.
Debugging Procedures Followed:
1. First I suspected the CD-RW drive then I borrowed a new drive and tested and that was not the problem, even with the new drive it was the same.
2. Then I thought it might be the OS problem(XP). Recently I updated a CD-RW fix from Microsoft. So I removed and tried, but even then the problem wasn't gone. So I tried on Win2k which also resulted with same problem.
3. Then to prove its the problem with Ulead software I then burnt the AVI files to VCD using NERO, which had come pretty good... With this I proved the problem is with Ulead Video Studio 6.0. The reason I like Ulead is it gives good menu creation interface and also editing the AVI files and adding some transitions was cool.
4. What I read from this forum is about the Plugin patch for Movie factory I installed that , even then it was failing.
5. Then there was a answer saying DVD Workshop's Sync patch fixes all these Audio Sync problem on DVD-Plugin. But that isn't true. I also read that it failed in this forum. But I tried my luck with out success.
The Behavior:
1. All I could notice is the Video is lagging about 1-1.5 Seconds behind Audio. Audio comes first and then the Video. This is prety much same all over the whole VCD.
2. After Rendering If you play the MPEG-1 file that plays pretty well. Once it is burnt to VCD there the problem starts. Then I tried burning the Mpeg file using NERO then also it failed. So with that I concluded the problem is out of Ulead's Rendering.
HELP HELP HELP
Pleas help me guys. I'm wondering how it worked for me earlier and what happened suddenly. Could this be some hardware problem other than CD-RW drive, Like the Processors MMX capability had gone bad or so????? I'm totally confused......
What Else I did to nail down the problem:
1. I installed on Windows 2000 - Failed
2. Installed on Windows XP Home - Failed
3. My Default will be Windows Professional - Worked earlier now its failing.
No where I could get a solid answer to fix this problem of Ulead Video Studio. Is there any other registry parameters or ini file parameters to be tweaked to set it right, if so please share with me guys...
Expecting all your help.
Thanks in advance
Rajendran.K
Results 1 to 1 of 1
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 04:10 -
h264 problem in Sony Vegas and Ulead Video Studio
By AscAnsio in forum EditingReplies: 1Last Post: 8th Jan 2010, 08:49 -
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 16:02 -
Sony Vegas Studio 9.0b out-of-sync video/audio on VOB files
By javaguy in forum EditingReplies: 2Last Post: 24th Mar 2009, 12:26 -
Slowing down video not Audio using Ulead Media Studio Pro 8
By engert100 in forum EditingReplies: 10Last Post: 25th Oct 2007, 15:17
