I currently have the Geforece 2 with S-VIdeo out. I have it hooked up and the picture works fine. But i am forced to use the sound from my PC. IS there anyway to connect the sound to make it play on my TV? Also how do I get the best quality out of the S-Video playing?
S-Video cable have 4 conductors (as you noticed), but none of them carry audio:
1 - Luma signal (the black and white part)
2 - Luma ground
3 - Chroma singal (the color part)
4 - Chroma ground
You knew this already (that was for other people's benefit). If you want audio, you'll have to use separate cables for it. Usually, you run a cable from your sound card's line-out to the RCA audio inputs on your TV or preamp/receiver, and you might need a Y-cable to go from 1/8" stereo mini-plug to RCA cables.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 15:44 -
no video but sound playing video with MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 30th Mar 2008, 03:05 -
video but no sound
By chas638 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2008, 05:39
