Closed Thread
Page 3 of 3
FirstFirst 1 2 3
Results 61 to 64 of 64
  1. Originally Posted by dellsam34 View Post
    Sorry that your thread went of the rail, This has been happening a lot lately. Other forums don't tolerate this, we are taking it for granted here.
    True.
    The derailing often happens when one feels obligated to chime in, commenting or correcting statements which are technically incorrect or an accumulation of half-truths which may be misleading users.
    Anyway, the OP has made a good decision IMO despite of all the "video experts babble" in between
  2. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Originally Posted by AquaCCD View Post
    Although I think the PCI card would work for me, I travel a lot and often only have my laptop with me, so for now, I think I'm going to go with the GV-USB2, with the possibility of upgrading my desktop computer in the (hopefully near) future when I am not on the go so much.
    Good choice. As long as you have a good player, a decent laptop and an IOData GV‑USB2 will allow you to get high‑quality captures.
    I may post an update later with some sample footage.
    Yes, post some samples of your captures here, so we can give you specific feedback and help with the post‑processing workflow if needed.
  3. Originally Posted by lollo View Post
    Luma depends on RGB→YUV conversion, gamma, color matrix, sensor processing, etc. and depends on the actual amount of light hitting the sensor.
    Finally, we agreed on something. I'll skip the rest of your BS for now.
    CCD is physically RGB device. It produces 3 electrical signals per pixel, which are interpreted as R, G, B. You know that, of course, don't you?
    We can't convert that YUV to standard RGB. However, according your logic CCD can easily produce such RGB!
    Have it ever crossed your mind to calculate what the electrical levels the CCD should produce to create such magical RGB, which could be then converted to YUV (225,210,180)?
    No? Well, I calculated. Your CCD needs to produce voltage equivalent to RGB (326,169,409) on 0 to 255 scale.
    I'm pretty sure you can easily prove that CCD won't saturate on that amount of light, diaphragm won't even bother close up, there is no voltage limiter on conversion matrix input, and that conversion matrix, whether it analog or digital, will single-handedly convert it to YUV.
    Please entertain me.
    Head switching noise? Use my Custom JVC VCR Service Remote Control (PTU94023B) to eliminate it!
  4. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    No need. You can bullshit yourself about your incompetence for as long as you like (You are just moving from "sensor physics and recording electronics" to a simple problem of color gamut mapping").
    I told dellsam34 that I would stop this off-topic discussion, and I'm a man of my word.
