i have a star wars 2 in bin and cue format and i was wondering how if it is possible to burn my bin and cue files to svcd or vcd? how do i do that, and what prog do i use?
as i don't know which version you got i can't tell you if you'll have problems(i know several have had probs with the sevcd version and had to extract the cd image with isobuster (www.isobuster.com)) if you get fireburner it's basically double click on the cue file and burn... with nero go to file, burn cd image, find the cue file and burn.
hope that helps -
Most burning programs should recognize them as an image. I use Nero and there is the option to "burn image." Once I do that Nero does the rest by writing the data to the CD. Use IsoBuster if you want to extract the data from the .bin file on your hard drive.
yeah, you dont need to tell the cd to be a vcd or svcd or anything, just load the cuesheet (i use cdrwin, shareware) and make sure the .bin file is in the same directory and burn away...
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
