Finally when I thought I was ready to start burning cds with cdrdao.....it throws another curve at me... now it says says it can't find device 0,0,0. Plus something about bus error. Apple system profiler states my burner as device 2.00, don't know if that helps or matter. The cdrdao website lists my burner as compatible using generic-mmc. Anyone know what a driver table is? And what am i suppose to do with a driver table?
Someone please help![]()
Seems I discovered what my problem was, I was cdservices when i should've been using DVDservices
I have a combo drive(cd-rw/dvd-rom) and so I guess it count as DVD. So if any of you combo drives owners run into this problem..do what I did, use DVDservices instead
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 18:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
