Hello. This is to people who have used Videoredo before, and have removed commercials, or ads, or whatever you wanna call them. Do you need to have a particular TYPE of video for it to work? I have a DVR, and it encodes it's files in .MTS format. They are in HD. I had tried to remove commercials with the software, but with not much luck. Anyone have any tips and tricks to pass along on how to get the software to remove the commercials?
VideoReDo's automatic ad removal (Ad-Detective) doesn't need a special file type, but it works best on clean broadcast transport streams, and DVR .MTS files often have small stream errors that throw it off. A few things that usually help:
1. Run Tools > Quick Stream Fix on the .MTS first, then open the fixed file.
2. Make sure you're on the H.264-capable version (TVSuite H.264). HD DVR recordings are usually H.264, and the older Plus version only handles MPEG-2.
3. In Ad-Detective settings, try logo detection: mark the channel logo area so it cuts where the logo disappears. Many channels no longer put black frames between ads, so black-frame detection alone misses them.
4. Treat the result as a first pass. Let it place the cut markers, step through them and fix the few it gets wrong, then save in the same format so nothing gets re-encoded.
If it still finds nothing, post a MediaInfo report of one of the files and people here can tell you what it's dealing with.
Replacement for Videoredo
By nicksteel in forum EditingReplies: 22Last Post: 17th Sep 2026, 06:59 -
VideoReDo alternatives ?
By hydra3333 in forum Latest Video NewsReplies: 389Last Post: 31st Jan 2025, 00:24 -
Can you automate VideoRedo
By cgott42 in forum EditingReplies: 5Last Post: 17th Dec 2024, 20:31 -
a sub can not be removed
By ghazalo in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2024, 09:22 -
Can this flicker be removed?
By DavidS in forum EditingReplies: 0Last Post: 29th Jan 2023, 04:58
