hey whats up?
i currently have two clips that seem to be fine (mpeg 2 captured with dazzle 2) i then use tmpg to join these two files together (in the merge toolbox).
Howeve once this is done and i try to import it into Spruceup for dvd burning about 53% i get the following message
"temporal gop out of sequence".
I recpatured the second clip and did the same, i still get the error but now at 40%
it mentions that a gop may be reversed.
Does anyone know what this is or why i get this message?
I believe it to be Tmpg causing this as if i input both clips separetly into spruceup their is not a problem. thanks for any help
Results 1 to 1 of 1
joining edited clips
By gargoyle62 in forum EditingReplies: 1Last Post: 22nd Nov 2011, 21:10 -
Joining several .MOV clips
By natty in forum EditingReplies: 18Last Post: 28th May 2009, 11:27 -
Joining 2 different video clips without re-encoding one of them?
By Og in forum EditingReplies: 2Last Post: 7th Jan 2009, 01:54 -
Interlacing artifacts appear from interlaced clips?? Sony vegas + tmpg
By mazinz in forum EditingReplies: 10Last Post: 28th Sep 2008, 19:51 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:32
