I have ATI TV Wonder VE, and the captures are fine, but the audio skips sometimes on my rips... And on my longer caps. the audio gets out of sync towards the end. Is there anything I can do to solve this? I can't use any other program with me cap. card except MMC, so that's all I got. All other programs can't locate my cap. device.
I think, it is capturing application (MMC) problem. I never used MMC,And on my longer caps. the audio gets out of sync towards the end.
but I have the same problem with MGI VideoWave. From another hand,
capturing with Ulead VideoStudio 6 is perfect. I would give a try to
another capturing application.
Strange, it should be visible to other programs too. May be MMC/ATII can't use any other program with me cap. card except MMC, so that's all I got. All other programs can't locate my cap. device.
original drivers prevent another programs to use the device somehow?
In any case, MMC/ATI original drivers are far from perfect. Try to
uninstall both of them and install good generic BT8x8 driver. With this
drivers you will able to try another capturing applications.
For good generic drivers try
http://btwincap.sourceforge.net/ (my personal choice)
or
http://www.iulabs.com/ (I did not try them, but heard they are good). -
I've already tried the btw48 or whatever drivers, and it wouldn't let me use the auto-install since I have windows98se. They tell me to install the drivers manually, but it NEVER works out... Any other help would be appreciated.
Audio skips
By tendo.kagwa@gmail.com in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2011, 12:26 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 21:56 -
recording audio using the ati tv wonder pro
By cadams8221218 in forum Capturing and VCRReplies: 4Last Post: 22nd Mar 2009, 19:12 -
New Pioneer 115D audio stutters/skips badly
By Captain Satellite in forum DVD & Blu-ray WritersReplies: 27Last Post: 19th Jun 2008, 19:27 -
MENCODER skips frames when dealing with MPEG-2 audio
By zuja9 in forum Video ConversionReplies: 2Last Post: 19th May 2007, 16:12
