Results 1 to 11 of 11
  1. How to decrypt a video when
    1) original encrypted video is deleted
    2) decrypted video has pink/green line due to wrong key
    Is it possible to re-decrypt as I have the correct key now?
    Mar 2026
    hongk
    mp4decrypt.exe --key <KID>:<KEY> <input file> <output file>
  3. No. That does not work without the original encrypted file.
    Mar 2026
    hongk
    Taking this video as an example, prepare two keys—one incorrect and one correct—to perform the decryption
  5. Decryption with the correct key will work, for sure. Decryption of a video that is already decrypted with the wrong key will not work. Regardless which key you use.
    Mar 2026
    hongk
    I decrypted my video using the wrong key; after deleting the original file, I decrypted the "wrong-key video" using the correct key
    Mar 2026
    hongk
    I overlooked an error: N_m3u8DL-RE encapsulates the format during download, and the encapsulated file cannot be decrypted
  8. Should be possible to recover IF your decryption tool did not remove the senc/tenc boxes
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  9. Absolutely impossible
  10. In theory it's possible but only if tenc/senc boxes are still there's which mp4decrypt and Shaka packager I believe remove.
