My MakeMKV software will no longer recognize any Blu-Ray disc, making transcoding impossible.
It will still recognize standard DVDs.
The problem has existed for at least a month.
I have uninstalled, re-installed and verified my serial number, but nothing I try fixes this issue. Very frustrating.
If someone else has had this problem, is there a fix?
Thanks.
I have now discovered that Blu-Ray discs are not recognized by my media software [Potplayer, VLC].
DVDs, however, play fine.
I haven't a clue why Blu-Ray discs have decided to stop working with any software, while DVDs are not problematic. Perhaps there is something within my WIN11 system that needs adjusting. -
This is because the blu ray laser in the optical drive in no longer reading the blu ray disc.
Meaning it likely has failed.
Do you have a decrypter like XReveal installed ?
If you do you can check if it is deccrypting the disc.
I have VLC set up to play blu ray discs.
This takes some work & adding additional files.
I checked a blu ray in the latest MakeMKV & it worked for me.
If you have a software blu ray player it is easier to test with.Last edited by cholla; 29th Aug 2026 at 14:21.
Per the name, Blu-Ray uses a separate blue laser versus the red laser of CDs and DVDs. So just the blue laser died. Very common issue. Also since burning discs requires more power, burning of all discs may fail, but reading may still be okay.
Has your drive played a Blu-ray disc yet?
If so, clear the drive's lower and upper filters and restart the computer.
Check to see if Blu-ray discs play now.
Google for upper and lower filters for dvd drive and follow the instructions.
How To Better "The Bad News Bears{1976}" Blu-ray Video
By LouieChuckyMerry in forum RestorationReplies: 20Last Post: 6th Sep 2026, 19:39 -
DVD Subs stay "on" ONLY on Blu-Ray Players
By acorngr in forum SubtitleReplies: 2Last Post: 23rd Dec 2024, 02:38 -
question about playing a Blu-Ray "rip" on a desktop computer
By rotchild in forum Newbie / General discussionsReplies: 2Last Post: 8th Jan 2024, 15:08 -
NON "English friendly" Blu-ray disc question.
By 2-perf in forum Authoring (Blu-ray)Replies: 10Last Post: 1st Dec 2023, 01:04 -
Can't play "wreck it ralph" blu ray in panasonic DMP BD605
By videdit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Sep 2021, 00:40
