Page 5 of 5
FirstFirst ... 3 4 5
Results 121 to 136 of 136
  1. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Originally Posted by itsonlyme View Post
    After installing both build 40 and 41 in each case version number still shows under help as build 39
    My Build 40 and 41 both showed up in "About SmartCut64" as they should, not sure why yours didn't.
  2. Huh, let me see what I've done.....
  3. Originally Posted by itsonlyme View Post
    Ah, it might be because of an install location bug I fixed. The previous version might have installed in the Documents folder as a fallback - if you have a shortcut it might be pointing to that location
  4. in the next update there'll be a search for duplicate versions, and an option to move the installation folder
    Feb 2004
    Crewe, UK
    Thanks Jon I'll check the location tomorrow
  6. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Hi, is there any way of backing up this Thread so it can be migrated to another forum in case this one goes offline again like what just happened in the past 24 hours.
    Anyway, i have posted up a comment over at the dumb Reddit Site (i won't call it a forum because it is not a forum in the same context as this one) and i will therefore not be posting any more stuff in that site, and hope that VideoHelp will survive forever.
    https://www.reddit.com/r/videoredo/comments/1vzuu4r/smartcut64_is_ready_a_new_64bit_ed...or_for_people/
  7. I am having an issue with file joiner. I am trying to join a clip I recorded off of cable to a rip of a blu-ray. Both are 1080p encoded in HEVC with 6 channel audio. The only difference is a very slight bit rate difference. The TV clip is 2,818 and the blu-ray is 2,863. Both were encoded with Handbrake. The output video plays but is very choppy.
  8. Member Bridgy's Avatar
    Aug 2024
    Sydney
    I'm no expert with TV or BD files, but i have had issues with the VRD Joiner in the past when trying to join what seemed like 2 identical files with a slightly different video bitrate, all were converted prior to this using Handbrake so in my case it just seemed like VRD just didn't want to play with Handbrake files.
    I know, or believe that SC-64 Joiner would work in an identical manner to VRD so it might be due to SC-64 not liking to work with files that were processed in Handbrake.
    The slight bitrate difference should not be the culprit here as i use the SC-64 Joiner every day with multiple identical files (same resolution and codec) but all with different bitrates.
    Is SC-64 recoding the files when joining them.
  9. I am joining without re-encoding. I had used VRD many time to join Handbrake encoded files without issue.
  10. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Ok well there is something else at play no doubt, so i guess Jon might pop in here and help.
    I hope you are liking this SC-64 as much as i am.
  11. Hi DrJekell,
    I tried joining two separately encoded 1080p HEVC clips, with six-channel audio and different bitrates, but I couldn’t reproduce the choppy playback. Can you send by file transfer both source clips and the joined output, to support@smartcut64.co.uk? It would also help to know which player you tried playing the result in, and whether the choppiness starts at the join or is present throughout.
    On a general note, for things like this it's best to email that address, as I don't check this thread every day.
    Cheers
  12. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Hi Jon, it's a good idea that people who need help should email you about their issue so that you can try to resolve it, but i would still encourage them to post up any issues they have here in this Thread as well just so that others can see it, and may be able to offer some help or advice.
    WitH VRD it was not a good idea to contact Dan Rosen via email because it would never be replied to, most of the time in the VRD Threads here in this forum, a lot of the issues reported were due to the user not doing something right, and those who had experience with VRD would often offer help or advice.
    I am always happy to offer help or advice when needed.
    Cheers m8, and keep up the great work, i have had no issues with any parts of my workflow using all kinds of file types.
  13. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Ok i now have an issue with build 1.0.44 which i had not tested yet using 4k-60p HEVC files from my recently purchased s26 Ultra phone.
    All of the 4k/60p HEVC files that i have been testing so far have been recorded on my s24 base model that i now very regretfully sold to upgrade to this POS s26 Ultra.
    I imported 3 different files so far, i cut segments at the start and the end and exported back to Same as Source, but in all 3 cases i got the following error (see video below) and it just hangs there and does nothing.
    https://streamable.com/m9746h
    I will upload one of the files and a screenshot of my profile so Jon can test this for himself.
    Also, in the Navigation Tab in the Options Settings, i really would like you to add an option to change the seek Time duration for the "Single Arrow" seek button as well as the double and triple button option, at the moment there is only the double and triple, plus a mouse wheel duration, which i hate using to seek with, maybe this was an oversight.
    I currently have the Double Arrow button set to 15 Sec and the triple Arrow button to 30 Sec.
    [Attachment 94352 - Click to enlarge]
    EDIT to above: I just took 2 of my s26 files that i had not cut and added them to the Joiner list, one was 60fps and the other was 59.940fps, and i also imported a 30 second duration black transition file (4k/60p hevc) that i use between scene changes in some videos, i placed the transition file between the 2 video clips and i did not cut the 2 video files, and i was able to export this project perfectly using my Same as Source Profile, with no recoding.
    As soon as i imported that joined file and made my cuts where i wanted them, the file failed to export with the same issue as seen in the video link above.
  14. Is there a way to manually type in how large we want the bitrate to be for the boundary encodes in intelligent smart render, because it uses the overall bitrate in the automatic (source aware), which oftentimes is horrible quality and I would like an option to bump that up, like in Smart Media Cutter where new boundary encodes can be lossless (high bitrate) if needed.
  15. Hi everyone, just a quick update on the reports above. Bridgy - I tested the next build on the Galaxy S26 Ultra clip you sent me. The trim finished, and the export decoded successfully. You can also set a custom interval for the single-arrow buttons under Program Options/Navigation now. The default is still one frame.
    SuperSilicon, there’s now a Smart render boundary bitrate setting under Tools/Edit Output Profiles. You can leave it on Automatic (source-aware) or enter a target in kbps for the sections re-encoded around cuts.
    I’ve also added File/Export Episodes from Chapter Marks, which was requested by another user. Mark the start of each episode after the first, then run the batch to get separate numbered files with your existing cuts applied.
    The Windows versions are ready to go out, I’m just preparing the Intel and Apple Silicon Mac builds now so they can all go out together. Might even be available by the time you read this
    Thanks,
    Jon
  16. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Thanks,
    Jon
    Ok using 1.0.45
    The Single Arrow Seek button is good, no issues.
    However, i still have the exact same issue with my s26 4k hevc phone files, i tested the first one i recorded last Saturday, it fails, i then loaded up a shorter clip recorded 10 minutes after the first one, that one cut and exported fin, the 3rd clip that i recorded and sent to you for testing is still not working on my end.
    Will record a few more sample clips and test those as well.
    EDIT: unfortunately 2 more clips that i just recorded failed as well
    Cheers
