Is it:
On A Playstation 2 DVD Player?
On A Dreamcast
On A Normal DVD Player?
Results 1 to 14 of 14
DVD player
We were all NEWBIES once and the only stupid question is the one that's not asked? -
Thanx Man Ill Just Buy A Cheap One Then I Guess. How Much Better Is Watching A VCD on A Real DVD and A PS2 DVD? Is It Worth Buying A Real DVD Player?
real dvd players have (some) mp3 and svcd support...
i'm not sure if PS2 natively supports VCD or u need to buy some kind of VCD adapter for it, which might end up costing nearly the same as a cheap dvd player
btw, xbox has better dvd playback than ps2 -
Is the quailty alot more better than DC? Is it worth buying a brand new DVD player?
It's actually better to buy a standalone DVD player because not every VCD or DVD will play in PS2 or DC. You can pick up a cheap one and "hack' the player to play region free and disable macrovision. Just crossrefernce the DVD hacks (on this site) and what ever the cheapest DVD players are in your area.
My shameless plug - XavierEnterprises.net -
Will this cheap DVD Player, play burned VCD's well?
http://www.walmart.com/catalog/product.gsp?cat=77934&dept=2637&product_id=1695844&path...A77934%3A77937 -
No. You only have to hack your dvd player if you want to view DVDs out of your region. The vast majority of DVD players play vcds(no region coding) and some are so inexpensive right now it's ridiculous. The best thing to do would be to check to see if the unit plays vcds(some player manuals refer to them as "digital video compact discs") The best way to research is to check out the units on this site like an earlier reply said.
Good Luck.
Hey Ghettorapboy7
there are other models of apex that you might want to look at as well check the dvd compatability list and check out this site for apex www.nerd-out.com it might help you decide which apex to buy.
Also marcusaxavier (I won't say you real name :wink:) is right hack it if you want it to be region and macrovision free.
I have the apex ad-3201 and after rebates at comp usa I paid $50, it plays all media without a problem
Good luck
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Ghettorapboy7 wrote
Feet up, fag in one hand, beer in the other.Whats The Best Way To Watch VCD's?
Craig -
for those of us in the United States let me just point out that craigtucker isn't saying "homosexual in one hand" -- "fag" is slang for cigarette in EuropeOriginally Posted by craigtucker
I just had to point that out :-) the imagery of the US translation was just TOO FUNNY :-)your pal,
Stinky
watch TV on my PC?
By wcwman18 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2011, 04:35 -
Whats your favorite type of movie to watch?
By johns0 in forum PollsReplies: 19Last Post: 1st Feb 2010, 05:01 -
is their a way to watch .avi on ?
By mrjust in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2009, 23:02 -
Where do you watch your DVDRips?
By Yoda4242 in forum Newbie / General discussionsReplies: 6Last Post: 30th Oct 2007, 11:52 -
watch TV on laptop
By ecos in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2007, 12:07
