Thanks for reading my topic.
Here is Linux Lubuntu 24.04.3 kernel 6.14 using a GT 640 driver 470.
I see when enconding using nvenc the file is much more big than if using x264 cpu enconding.
Why happen it ?
I have tested using and disabling b frames and is the same result.
Have a nice week.
Results 1 to 11 of 11
NVENC encoder usually need more bitrate to deliver same/comparable quality - software encoders usually offers higher compression at a cost of encoding time - hardware encoders such as NVENC usually need to use simpler encoding techniques but in exchange they offer encoding speed way higher than software encoders - there is always trade-off between bitrate/quality/encoding speed
Depends on CPU and quite important - x264 at veryfast preset probably will require higher bitrate to deliver same or comparable quality to one offered by NVENC is highest quality settings - so still NVENC may be better in situation when you can accept bitrate higher for example by 20% but your goal is encoding speed.
It could be interesting exercise to check where is intersection point (x264 vs NVENC) - sadly i can't perform such exerciser as i have no NVidia card equipped with NVENC (and AMD video encoders are way worse than NVidia) - perhaps Intel encoders can match NVidia. -
I do not think the he is really using nvenc => https://forum.videohelp.com/threads/420970-Why-b-frames-not-does-less-file-size#post2801937
users currently on my ignore list: deadrats, Stears555, marcorocchini -
... using a GT 640 ...
@Aug: compared to modern H.264 encoders (hardware or software): no
compared to H.264 software encoders like x264 from that age, you probably have to increase the bitrate by 30-50% to get the same quality (compared to current x264 compression, probably more like 50%)users currently on my ignore list: deadrats, Stears555, marcorocchini
need to efficient encode x264 this file
By marcorocchini in forum Newbie / General discussionsReplies: 20Last Post: 19th Feb 2026, 12:39 -
File size 3x bigger when using Avisynth trim function through VDub2
By VideoYak in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2023, 06:58 -
Can you beat the quality/size ratio of PAL Mpeg with X264 FullHD?
By Bencuri in forum Video ConversionReplies: 2Last Post: 14th Dec 2022, 04:44 -
Is x265 half size reduction compared to x264 a real thing ?
By Yertq in forum Video ConversionReplies: 13Last Post: 23rd Jun 2022, 06:04 -
What's NVENC H264 CQP for X264 CFR 18 and 23?
By Flagship in forum Video ConversionReplies: 2Last Post: 7th Jun 2022, 09:18
