I can download a movie, and burn the disks. Then play it on stand alone DVD Player, Sony. The first one will work and play fine, the second half wants to stall every 2 seconds. this happens with quite a few movies lately. Using Nero vcd to burn. and nero does not ask me to recode. VCDgear to go from bin/cue to mpeg. Can play movie on Computer with no problams. Any suggestions?
grampa
Your problem is probably your player you did say its a piece of junk. :lol:
SONY all talk no action :lol:
Seriously try playing it on another player from friend/ neighbor and see how the second disc works.It's either that or some bad frames in downloaded movies.
Good luck
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Oohh man that hurt, but I did feel the same as you did. Thought it might be the DVD "by Sony". Will try some other DVD players and see what gives.
grampa -
sony dvd players are good. as for your problem, try running the mpeg on disc 2 thru VCDgear's error correction if you didnt do that when extracting from bin/cue->mpg
Visit my webpage at:
http://leech.at/e-z-e -
Used VCDgear and those settings, gave the disks to some other people. Worked on theirs, not mine. Have had some issue's with DVD's I bought. It is the machine. Thanks for the reply. THinking about an Apex Machine, what the heck do I have to lose for $100.
grampa
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
ProCoder 3 dosn't export mp4 AAC audio
By SheFeiLong in forum Video ConversionReplies: 0Last Post: 27th Oct 2011, 04:53 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 06:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 05:51
