Has anyone made this combo work?
If so, can you please post workflow, what to download to make this Magix Vegas 22 (before Boris purchase version) and free Voukoder (core + connector). Thanks for any input.
I have and use a combo like this.
https://files.fm/u/zepcauxs25
Downaloder voukoder*. Install.
Download *connector*. Install. -
If you want to render to mp4 (or another format), then with this combo you need to:
1. Export the video in the target format (without audio).
2. Export the audio as a 32-bit WAV (or 16-bit - whichever you prefer).
3. Combine both exports using ffmpeg, something like this:
ffmpeg -i video.mp4 -i audio.wav -map 0:v -map 1:a -c:v copy -c:a aac -b:a 192k output,mp4
When rendering directly to mp4, the audio will be shifted by about 3 frames and the last 3 audio frames will be cut off.
Anyway, check it out, because I don't know exactly what version of Vegas you're using.
You can export video+audio in the first step, then merge with wav and check under VirtualDub if it is ok.
If they are offset from each other, then the track from wave will be the correct one. -
Thanks,
so I'm assuming you have actually version 22 and Voukoder. Was there anything specific to install that setup, did you "uninstall" previous Voukoder and install that particular setup, or you use it without uninstalling previous versions?
Magix Movie Pro 14 - MP4
By DLT in forum Newbie / General discussionsReplies: 1Last Post: 24th Feb 2026, 20:43 -
Frameserving to Vegas Movie Studio or Vegas Pro
By stymie in forum Video ConversionReplies: 22Last Post: 6th Jan 2023, 00:58 -
MAGIX analogue capture device problem on Win 10
By OldTech in forum Capturing and VCRReplies: 28Last Post: 12th Dec 2022, 15:39 -
Vegas 18 - source is BT.601, wow to set it up in Vegas?
By rgr in forum EditingReplies: 0Last Post: 24th Jun 2022, 06:47 -
Properly muxing Magix Vegas rendered raw AVC stream?
By lpmaskman in forum Video ConversionReplies: 4Last Post: 10th Feb 2022, 13:50
