Page 5 of 6
FirstFirst ... 3 4 5 6 LastLast
Results 121 to 150 of 151
    Jul 2017
    Los Angeles
    I saw someone mention that D8 camcorders have TBC? Did I understand that correctly? Do ALL of these cameras have this feature?
    Some D8 camcorders have TBC. My understanding is the TBC is inoperative on pure Digital 8 tapes because the video is digital (aka Firewire). The TBC is used when playing analogue tapes ie Video8 or Hi8.
    It has been claimed that the TBC in these D8 camcorders functions on the passthrough signal (eg VCR to Firewire) but I can't see it in the test I did in post #59 so I remain to be convinced.
    You'll have to check each model number; this wiki shows which Sonys do Passthrough.
    All D8 camcorders can output over Firewire.
    As for the Ebay prices, hard to know... perhaps we've passed peak video-transfer? And watch out for the fakes... from our very own VWestlife, a YT video on the subject:
    https://www.youtube.com/watch?v=OG46lGBwa_s
    Re your Firewire 400/800, you can get adapter cables with 4-pin FW400 on one end and 9-pin FW 800 on the other eg this one.
    Alrighty.. Thanks
    Aug 2018
    Wrocław
    - DV's inferior color subsampling (4:1:1 for NTSC or 4:2:0 for PAL) as opposed to 4:2:2 for recommended lossless analog VHS captures.
    With VHS and its low horizontal chroma resolution, YUV411 is worth the same as YUV422.
  3. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    And while there, 4:1:1 was designed as good digital approximation of the analog consumer formats (540 luma lines, 120 chroma lines). VHS/S-VHS feature 240/400 luma lines and <50 chroma lines, so theoretically fits well despite the constraints of its subsampling.
    The downside of 4:1:1 is that the chroma resolution is so low that it is clearly visible (if not properly low-pass filtered, but that's another story)
    As I wrote earlier, 4:2:0 means dropping every line of full horizontal resolution color in exchange for vertically higher color resolution, which is not adequate for surces with low chroma resolution.
    In principle, 4:1:1 better fits the full horizontal resolution and low vertical resolution of consumer formats while 4:2:0 looks better for sources with high vertical chroma resolution, where 4:1:1 would lose significantly more vertical information than horizontal information. Of course 4:2:2 is better
    Aug 2018
    Wrocław
    There are so many errors here that I will only correct the last sentence:
    In principle, 4:1:1 better fits the low horizontal resolution and full vertical resolution of consumer formats while 4:2:0 looks better for sources with high horizontal chroma resolution, where 4:1:1 would lose significantly more horizontal information than vertical* information. Of course 4:2:2 is as good as 4:1:1 (for VHS)
    * - he loses nothing here
  5. Attached 4 (synthetic) cases with U,V chroma resolutions for different 4-x-x formats. Take what you think "fits" your (interlaced) VHS/S-VHS captures "best" or adequate
    Edit: Keeping in mind that NTSC has a lower vertical resolution than PAL (480 or 486 for NTSC vs 576 for PAL) the decision for DV may have been to NOT sacrifice any vertical chroma resolution but to compromise on the horizontal resolution instead, hence 4:1:1 for NTSC.
    For PAL the compromise is made on the vertical chroma resolution, at the benefit of higher horizontal chroma resolution, hence 4:2:0.
    Just speculating.
    Obviously, 4:2:2 is the best compromise for both NTSC and PAL with respect to chroma resolution deficiency, with 4:4:4 just being overkill.
    Aug 2018
    Wrocław
    Was the source 4:1:1 material - as it is actually captured from the VCR?
  7. Originally Posted by rgr View Post
    It explains the principle. You can take any dodgy source and argue on your own.
    Aug 2018
    Wrocław
    But not for showing the differences with a VCR source.
    In fact, you could use an HD source and demonstrate that it's worth saving VCR files in HD, as it's better than SD.
    Your source should look something like this, to match VHS:
    ColorBars(720,576,"YUV444").KillAudio
    chroma=BilinearResize(60,288).BilinearResize(720,576)
    luma=BilinearResize(360,288).BilinearResize(720,576)
    MergeChroma(luma,chroma)
    ConvertToYUV444 # YUV422,411,420 etc.
    Now check the differences.
  9. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Sure
    No! As I wrote, for capturing VHS and S-VHS 4:2:2 is better than 4:2:0 and 4:1:1
  10. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Yes, that's the story, as I wrote earlier.
    Yes, but 4:2:0 was introduced/better fits sources with "high" chroma resolution, not VHS/S-VHS.
    Absolutely!
  11. @rgr post #128: The principle of color subsampling and associated chroma resolution is independent of the source. You can emulate or use any source, emulate or use a good or worn VCR, declare this as your "VCR/VHS reference" and then argue - or worse even generally conclude - that "one cannot see a difference" between various subsampling schemes.
    Aug 2018
    Wrocław
    Sure
    You don't have to confirm, I know. I corrected it.
    Of course, capturing non-existent values is very important. So also consider capturing in FHD.
    Aug 2018
    Wrocław
    The differences are visible, of course most noticeably in (high-quality) laboratory samples. This does not hold here.
  14. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    I corrected it.
    You cannot correct anything, because you are wrong. You can keep arguing with your crap AviSynth emulations instead of real VHS/S-VHS signals in proper workflows as long as you want, but capturing at 4:2:2 is better.
    End of the story.
    Aug 2018
    Wrocław
    I corrected it.
    Maybe you should just learn to read and speak logically? Without confusing basic concepts?
    You can keep arguing with your crap AviSynth emulations instead of real VHS/S-VHS signals in proper workflows as long as you want, but capturing at 4:2:2 is better..
    It hurts so much you've never been able to do any tests? Okay, let it hurt. It's supposed to hurt
  16. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    I never test with "emulated sources". Just use real excellent tapes, in real excellent worflows, with real excellent expertize.
    As you realize, no reason to be hurt!
    Aug 2018
    Wrocław
    I told you it was worth abandoning JVC.
    Phew, I was already afraid you were doing it yourself!
  18. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    What you say doesn't matter at all
    Jealous, right?
    Aug 2018
    Wrocław
    phew, i was already afraid you were doing it yourself!
    jealous, right?
    :d :d :d
    Jul 2017
    Los Angeles
    Hey folks, if anyone’s still paying attention to this... I came across a YT video by @VWestLife, here: https://www.youtube.com/watch?v=OTOChbbTRgs&t=11s
    The workflow seems simple: [VCR] to [DVMC or TBC-capable digital camcorder] to [firewire-capable computer]. I’m sorry if this was discussed, but there was information overload here, plus a few too many arguments, that I may have lost it in all of that. This may not matter anyway, as I am doubtful that my HV30 actually has a TBC. But, I am just curious about this.
    However... if the Sony device can go directly between my VCR and IEEE-1394 machine, then that would seem to be a perfect solution, no?
    (Still prepping my MacPro tower. I got the hardware in place, I just have to make the time to install the 16yo OS.)
    Aug 2018
    Wrocław
    There is nothing there that hasn't already been said here long ago.
    Finally start taking action before Lollo shows up with his "pearls of wisdom."
  22. Member
    Jul 2017
    Los Angeles
    Well, that was my point: I was unsure if it had been described or not, since there was so much info being offered, and this interspersed with argumentation. It becomes a bit overwhelming to read, in depth, each post.
    I was going to pursue the DVD-recorder route, but this seems simpler, there being one less link in the chain. Unfortunately for me, it also may be the more expensive route, since these devices are going for $hundreds on eBay. Anyway, I have two courses of action that have their own appeals. I’ll make a decision and, if anyone’s interested, I’ll post the results once I get started.
    Making progress here... slowly, albeit.
    Thanks for your help and patience guys. Just a little concerned about making the wrong decisions, and then having to make trips to post offices to return items, be delayed another few weeks, throw money away that I don’t have to throw away, etc.
  23. Member
    May 2005
    PAL User
    You're right, but it's impossible to see in amoungst all the carry-ons by you and others.
  24. Member
    Aug 2018
    Wrocław
    Everything was written in the first posts.
    But I have a question about the device in this video - does it use the standard DV codec or one of the "Pro" versions?
  25. Member
    Jul 2017
    Los Angeles
    That would be a question for VWestLife, I think, but I heard him say “DV” often. If he said “pro”, I missed it, but I planned to watch it more carefully if I decided to go that route anyway.
  26. Member VWestlife's Avatar
    Mar 2026
    New Jersey, USA
    Just like the DV passthrough mode of MiniDV and Digital8 camcorders, the Sony DMVC outputs standard DV, not DVCPRO (which was Panasonic's format) or DVCAM (Sony's equivalent of it).
  27. Member
    Jul 2017
    Los Angeles
    Which seems perfectly fine for VHS cassettes, no? Or, does a mini-DV pass-through do more for the final product?
  28. Capturing Memories dellsam34's Avatar
    Jan 2016
    It depends on the processing chip of the camcorder, Some low end camcorders tend to mess with the levels and chroma, The DV codec itself is not that harmful for capturing despite being 4:1:1 for NTSC and 4:2:0 for PAL, The limitation of DV is if you are planning to do some restoration later you are better off with lossless AVI 4:2:2, You don't want to post process from DV analog sources.
  29. Member
    Aug 2018
    Wrocław
    There are no particular issues with restoring DV recordings. I would even say that the more advanced the processing, the less it matters.
  30. Capturing Memories dellsam34's Avatar
    Jan 2016
    Good for you.
