Results 91 to 120 of 151
D8 cameras have TBC. Do yours have it and if it works good you need to check or search the internet.
The easiest way would be to look for someone who has FireWire, rip a snippet of that tape you have, and check it out.
If the result is OK, then you have the problem out of your head.
If the result is bad and waviness still occur, you need a passthrough device with TBC (Panasonic DMR-EH5x), between the VCR and the D8 camera. Or buy a grabber and use it instead of a camera. -
Where do you see the need for de-block (attachment)?
1. You capture in YUV420, encode in YUV420 and see a problem somewhere?3. It is the opposite, because 4:2:0 reduces color resolution both horizontally and vertically (by half in both directions).
This can be problematic for formats that already have little color information such as VHS and S-VHS, as the chrominance is further reduced. Pratically 4:2:0 is taking away color from a signal that already has very little of it causing blurred colored edges, color bleeding, aliasing, loss of fine saturation and banding.
Of course with poor sources the difference is minimal, but for nice VHS and S-VHS is not so small.
Strange, because with luma 16-235 on the input and output it doesn't bother you
The human eye is more sensitive to luma than chroma.
2. More damage than the YUV420 on the input is done by JVC with his "temporal smoothing".Last edited by rgr; 30th Jul 2026 at 17:22.
Sure!
The gaps and spikes in the histogram is another story, charlatan, and not all grabbers feature that.
Tell me now that you capture in 4:2:0, which is a loss, but in 10 bits, which is completely useless.
I have a different opinion about who is not understanding, but I do not care at all. -
Do you expect me to loose time checking your videos? DV introduces blocks by default and by the law of physics and maths; if there is a sample with minimal artifacts is not the rule (the same as per your crap experiment).
We keep the luma and the chroma as there are on tape. There is not need to deteriorate chroma more.
The rest about levels and sensitivity is absolutely out of contest.
That's the last of your bullshit.
While a temporal noise reduction is present, is not worst than what youobtain with a temporal denoiser avisynth filter with high temporal radius. If the starting point is cleaner, there is less need to use strong settings. And the final result is equivalent.
JVCs are wonderful machines (not all of them of course). Once more look to real examples of mine comparing a signal dumped directly from a satellite stream and its brother who has been recorded by a JVC on a tape and then captured. No difference, which validate the full chain! -
You could use some for training, because you're already pushing harsh nonsense, Dr. Professor of Theory
Civil courage a little, show these blocks.
Dr. Associate Professor of Theory, there are no bytes on the tape, there are volts
It's such an analog monster! The more precisely you sample it, the better the reproduction you'll get.
Well, I seeThat's the last of your bullshit.
The frame from JVC is the one below...JVCs are wonderful machines (not all of them of course)
Even the YUV444P16 wouldn't help here, but the good news is that no YUV will hurt more... -
You need that DVD recorder before your HV30 (the HV30 does not do any stabilising according to my test).Originally Posted by Kong
For a better result, instead of American (4.1.1 colour) Firewire, go the lossless route, capture with a USB digitiser such as the GV-USB2, USB-Live2 or 710-USB (although the 710 doesn't work on Win 10 or 11 here). Then edit your files with Premiere (what format AVIs does it accept?). The lossless process is more complex than the DV route.
So, get your hands on a suggested DVD recorder, do a HV30 capture and assess. Looks good? Stick with that. Not happy, or feeling a bit nerdy, move up to the lossless route. -
Well, my sturdy JVC HR-S9500 smoothes the picture even when disabling all of its internal filters (which can be disabled by the user), and some of the details (like fine vertical structures) cannot be recovered in post. For this reason I prefer my Pana NV-HS860 for capturing. It captures more details (provided these are on the tape) and more noise, but the details are preserved after denoising in post.
It may be more prominent for home videos than for preprocessed broadcast or commercial tape material though.
Apologies for adding to the off-topic stuff
In my case is the opposite because the JVC is better than the Panasonic, and I posted a comparison in the forum some time ago. Cannot find it now.
Sorry, re-end of the off-topic
The last two posts are not what the OP or me was calling "off topic".
They are VCRs that if the OP decides to go that route may correct his VHS captures.
It was the "your way is wrong & mine is right" That got into the posts.
In other words "A pissing contest". -
@ lollo,
I'm not going to go there.
Try your insults on some member that want's to go back & forth with you.
It is too easy to do online.
Since I doubt we will ever be face to face .
You would not want to insult me face to face.
I will end with this quote by someone I respect:
“I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.”
BTW: That does not mean I won' post again in this topic.
But not back & forth with YOU ! -
I think people here should at least act the age of the equipment they're arguing about.
Hey...
I looked up some capture devices online. They’re not prohibitively expensive. But, if I can get away with a VHS -> DVD recorder -> Camera / FW -> computer, and it works, that’ll be complex enough for me
I like your solution, and will weigh this in my brain. But, honestly, it’s simple and I like simple, being a simple man
Thank you. -
My fault, not being clear.Originally Posted by Kong
In a nutshell, the DVD recorder is the stabiliser (I'm not going to call it a TBC because it technically isn't).
So, the two options are:
VCR > DVD recorder > HV30 > Firewire capture
or
VCR > DVD recorder > USB digitiser > lossless AVI capture -
Not "necessary". But lossless gives you better raw material to work with when improving it, for example denoising.Originally Posted by Kong
The DV route is simpler. And the result is all in the eye of the beholder... you may well be happy with that.
At this point, I'd move from concept to action. FW cards are cheap, buy one and do some captures using your HV30.
Attach a couple of short ones here for assessment.
Then you can decide if you need a stabiliser ie DVD recorder between the VCR and the HV30.
Or whether you go a step further to a lossless workflow. -
Reminds me of Burgess Meredith in “The Obsolete Man”... “I’m a wealthy man.. I have so many choices.”
1. I know everyone’s saying “Just buy a FW card and get started...”, but I have other reasons for taking my time: I saw someone mention that D8 camcorders have TBC? Did I understand that correctly? Do ALL of these cameras have this feature? I have multiple D8 cassettes that need to be re-captured (since I accidentally deleted a bunch of these files years ago, and this would be a way to kill two birds with one stone). I’m looking on eBay now for one, and am seeing some insane deals (one was “brand new”, or at least unopened, and they’re asking $30 or something for it?. Too good to be true?) Any recs here? Not to start another thread, just curious to know some thoughts on hunting one of these down.
2. Secondly, I want to also use this project as motivation for getting my MacPro tower (equipped with FW800 onboard) up and running, and plan to install period-correct Snow Leopard onto it. This ought to give me the version of iMovie that I need (if not for a D8 camera, then for my HV30).
If this winds up taking more time than I hope, I can opt in for the general suggestion here to purchase a FW400 card. Heck, I could do that anyway if I get this 16yo machine going. (My Win11 workstation seems to be limited in PCI slots, or my thick RTX 3080’s covering them).
Anyway, I’ll get to this as soon as I am able, and will start a new thread for tests / samples. In the mean time, I think I will save this thread into a text or Notes document for direct referencing.
Thanks all!Last edited by Kong; 1st Aug 2026 at 15:04.
Some D8 camcorders have TBC. My understanding is the TBC is inoperative on pure Digital 8 tapes because the video is digital (aka Firewire). The TBC is used when playing analogue tapes ie Video8 or Hi8.I saw someone mention that D8 camcorders have TBC? Did I understand that correctly? Do ALL of these cameras have this feature?
It has been claimed that the TBC in these D8 camcorders functions on the passthrough signal (eg VCR to Firewire) but I can't see it in the test I did in post #59 so I remain to be convinced.
You'll have to check each model number; this wiki shows which Sonys do Passthrough.
All D8 camcorders can output over Firewire.
As for the Ebay prices, hard to know... perhaps we've passed peak video-transfer? And watch out for the fakes... from our very own VWestlife, a YT video on the subject:
https://www.youtube.com/watch?v=OG46lGBwa_s
Re your Firewire 400/800, you can get adapter cables with 4-pin FW400 on one end and 9-pin FW 800 on the other eg this one.Last edited by Alwyn; 1st Aug 2026 at 23:31.
Newbie VHS Digitizing
By Darwin4Ever in forum Newbie / General discussionsReplies: 9Last Post: 4th Jan 2025, 10:00 -
How Do You Recycle VHS Cassettes
By Subtitles in forum MediaReplies: 6Last Post: 16th Dec 2024, 15:17 -
Digitizing homemade VHS videos
By tomini in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2023, 21:06 -
Getting started digitizing VHS collection
By planetearth in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2023, 11:26 -
I need help with color flickering digitizing my VHS tapes
By HansensUniverse in forum Capturing and VCRReplies: 2Last Post: 1st Feb 2022, 06:08
