    Jul 2026
    Oslo
    https://github.com/maas3n/autobuildffavs
    The script builds and installs ffmpeg & avisynth+ with checkinstall. ffms2 & yadifmod2 gets build and installed without using checkinstall.
    Be sure to add: contrib, non-free, and non-free-firmware to your APT sources before running the script.
    I have also added a .avs template and some basic syntax examples for usage with ffmpeg
  2. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Nice! Glad to see I'm not the only Linux user here. I do use wine with avspmod though as sadly there is no native Linux avs editor gui that I'm aware of. Speed difference in 64 bit is negligible as long as I pipe it to a wine instance of ffmpeg.
    if all else fails read the manual
