I was wondering if anyone knows how to have nero re-encode videos if it does not ask you to. Normally if the video is not encoded properly it will ask you if you want to re-encode it. However, it detects PAL videos (352x288) as being OK for NTSC VCDs. Its freakin annoying cause I left a CD to encode/burn overnight and half the videos don't work because I forgot to check the frame size.
