I don't know if this has been asked before, but does anyone know if Subtitle Edit and/or Aegisub allow you to position the subtitles so that they're in a 4:3 safe area? If so, how can this be done?
For the most part, position is controlled by the subtitle renderer, not the subtitle file.
For SRT there are some HTML tags that are supported by some renderers. Most of the advanced software players on a computer support them but few TV's or DVD/BD players do. You can use the files in the following post to test some of the advanced SRT options:
https://forum.videohelp.com/threads/332300-How-to-position-a-subtitle-in-a-srt-file?hi...st#post2543525 -
Here's instructions for Aegisub.
Display-related
Detach video
Detaches the video display and related controls from the Aegisub main window and moves it into its own window. To reattach the video to the main window, close the detached window. This feature can be particularly useful on multi-monitor setups.
Set zoom
Sets the video zoom level.
Override aspect ratio
Stretches the video to the specified aspect ratio by modifying the video width. Useful for anamorphic video (see above).
Show overscan mask
Draws a blue "mask" over the image, indicating the edges of the action safe (dark blue) and title safe (light blue) areas. Useful if you plan on showing your subtitles on a TV without adjustable overscan correction. For more information, see the Wikipedia pages on overscan, safe areas and overscan amounts. Aegisub follows the BBC guidelines on how big the safe areas should be.
https://drpleaserespect.github.io/aegisub-documentation-backup/Video.html -
I don't remember what program I used to use to edit subs, but as I recall, it had a option for how many characters per line (typically 40 or 80 depending on font size), and I would set it to 2-3 characters less to ensure it stayed on screen. This is a carry over from my early PC days where screen resolution was limited to 40 or 80 characters.
GV-USB2 - Possible to capture more visible area?
By ENunn in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2025, 20:19 -
Am I safe
By cns00 in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2023, 05:07 -
Frame area
By coolgit in forum RestorationReplies: 2Last Post: 13th Jan 2023, 09:30 -
How to show subtitles BELOW the video area
By jarce2000 in forum SubtitleReplies: 9Last Post: 1st Dec 2022, 16:20 -
How to crop an area from a video using AviSynth?
By ziptip in forum EditingReplies: 2Last Post: 3rd Jan 2022, 02:19
