One question for you guys........is it possible to rip two movies to your hard drive, and then open up two windows of TMPGE and encode two movies at once?? The system I am running is AMD 1700, 256 ram, 40gig HD, Win ME. I've started trying it to see if it works, and I can run two lots of TMPGE while encoding, but will the encoded versions have glitches in them like no sound or anything like that?
Cheers
Pnut
Yes, you can run two or more TMPGEnc jobs at the same time, but if you are expecting to save time, you will be disappointed. If you try to run 2 at the same time with the same priorities, the two jobs will just evenly split the available CPU. The result is that the two movies will be done at approximately the same time, but that time will be equal to the time it would take to run each job consecutively. In other words, you haven't gained anything. It is better to use the batch feature in TMPGEnc and load multiple jobs. Only 1 job runs at a time and the next job starts immediately after the first has finished. There is one more advantage to batch over simultaneous jobs. Lets say that you have 5 movies being done at the same time (5 seperate TMPGEnc processes). Lets also say that the priorities are all the same (if 1 is set high and the others low, the 1 set high will get more CPU). Now lets assume that it would normally take 4 hours for each movie or 20 hours total to complete. After 19 hours and 59 minutes you have a power failure. You have just lost ALL of the encoding on ALL 5 movies. Now lets say you were running in batch mode instead. When the power failure occurs, you will lose the LAST movie that was being encoded, but the other 4 will be finished. Bottom line = use batch mode.
XVD4PSP 5.0-6.0 encoding for HD movies terribly slow on Win 7 64 Bit with..
By pectin232 in forum Video ConversionReplies: 2Last Post: 25th Nov 2010, 20:28 -
Best VirtualDub codec for encoding Hi8 movies
By jranaudo in forum Video ConversionReplies: 7Last Post: 14th Jan 2010, 09:12 -
Defining the MB in movies when encoding in GK
By Fire Foxer in forum EditingReplies: 13Last Post: 5th Nov 2009, 15:53 -
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video Streaming DownloadingReplies: 29Last Post: 1st Aug 2009, 19:23 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 14:13
