Results 1 to 10 of 10
    Aug 2023
    Germany
    Currently used Kubuntu 24.04. Wayland, ffmpeg 8.0
    Did compress the video :
    Video: h264, yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 11343 kb/s, 50 fps, 50 tbr, 90k tbn
    to :
    Video: hevc, yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 5075 kb/s, 50 fps, 50 tbr, 16k tbn
    h.264 video-file size= 9GB. h.265 video-file size 3.7GB
    VMAF score: 99.836461
    the respective ffmpeg command as a script :
    #!/bin/sh
    for f in *.ts; do ffmpeg -y -i "$f" -map 0:v -map 0:a -vcodec libx265 -crf 16 -preset slow -vf nlmeans="1.6:7:5:3:3",unsharp="3:3:1.0" -c:a copy "$(basename "$f" .ts).mkv";done
    A short description :
    crf 16 = quality, less value higher quality
    nlmeans = filter to reduce grain
    unsharp = increase sharpness
    Without the filter unsharp. I got a file size of 2.4GB (same video) and a vmaf score 95.6 .
    For your information vmaf score of 100. no difference can be seen. 95.6, a good value.
    Never reached this high vmaf score without "unsharp". I did decrease crf until I got a compressed file size < 1/2 source file, but the vmaf score max was 96-97.
    Also I did compress with "unsharp" other videos with very equal results (vmaf score > 99.9)
    I have a restriction : If I can not reduce the file size with crf 16, unsharp as given above to 1/2 of the source file-size. I decide for no compression.
    Only to share my results.
    Others who would like to share their results ?
  2. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Ah yes the fun metrics rabbit hole. Take them as a guide not concrete. I've gotten hight scores before but the background gradients etc were gone. And I've had home with a lower score (92) look fine visually as the gradients got preserved, just not exactly like the original.
    if all else fails read the manual
    Aug 2023
    Germany
    @dannyboy48888, yes and no. I got bad vmaf scores e.g. 55 but acceptable results checked by vivictpp or via TV.
    But this case I can confirm e.g. by vivictpp, I did not see any differences in the pictures, frame by frame.
    And it does not depend on the background/foreground.
    And also as given by my example, I could see differences with vivictpp and the vmaf score 95, but not with a vmaf score of 99.
    Aug 2023
    Germany
    But we have the possibility to check the "subjective" results with a respective upload :
    https://we.tl/t-R2sLFzDOX9ypuf2c
    The link will be for 3 days available.
    From my side of view, the given webpage should be checked before to download my files.
    Aug 2023
    Germany
    An additional hint : vmaf developed by Netflix engineers + some US-Universities + ffmpeg community to get a metric for its own, the Netflix encoding results. And if a vmaf score of > 99 would be indicate not an on top result, the logic leads to : Neither Netflix engineers nor some US-Universities nor the ffmpeg community does not know what they speak about, I must confess, I can not believe it.
    Aug 2018
    Wrocław
    Aug 2023
    Germany
    @rgr. I must confess, I have no eyes for cheap sharpening, did you see the context of the picture ?
    Better it would be, to send 2 pictures, the first you did send and the second, the cursor a bit to the right, then you can compare source/target, the context you have to accept all ways.
    But every body can do it, it does not depend on you (vivictpp a tool for free, WIN +Linux).
    But I must also confess, to indicate "sheap" sharpening, at a position where the light is totally different (left, right), has to explain its choice.
    Obviously you are also the opposite of Netflix engineers + some US-Universities + ffmpeg community ?!
    Are you also the opposite of tools for free ?
    Aug 2023
    Germany
    And further results with vivictpp : https://we.tl/t-StWaSjJp3RkPmpYo
    Two pictures left and right of totally different light.
    But @rgr, if it is not the correct timestamp, give me the timestamp, I can give also for further investigations the respective pictures (refer to vivictpp : https://github.com/vivictorg/vivictpp).
    Apr 2012
    Hungary
    to :
    #!/bin/sh
    Can I use ffmpeg 8.0 on Windows 7 running your script?
  10. I usually do not use scripts.
    I used the code necessary for the command line in ffmpeg.
    ffmpeg -y -i "input.mp4" -map 0:v -map 0:a -vcodec libx265 -crf 16 -preset slow -vf nlmeans="1.6:7:5:3:3",unsharp="3:3:1.0" -c:a copy "output.mkv"
    I'm using:
    ffmpeg version 8.1.2-WIN7 Copyright (c) 2000-2026 the FFmpeg developers built with gcc 16.1.0 (Rev5, Built by MSYS2 project)
    It is one of the ffmpeg that was posted in this thread:
    https://forum.videohelp.com/threads/414767-ffmpeg-7-0-1-and-Windows-7/page6
    The current version being posted is a version 9.
    A version 7 may still be posted but I'm not sure.
    autodidact the member creating the versions for Windows 7 is real cooperative & may be able to post a ffmpeg version you want.
    I have the 7zip for the version 8.1 still but it is for Windows 7 32-bit.
