Ok I think I have finaly got the hang of this encoding thing now.
I did my first film Ali G in SVCD fine onto 2 disks !
Ok my problem is like this, I went to do my next film using the exact settings. Once burn't up It plays fine and the audio is in sync. But the video is not smooth is is almost as thought there is a frame missing out of every second of video, I have tried diffrent films and they still come out the same.
I have also tried a fresh copy of TMPGE.
I thought it was nero at first because I upgraded, but I have just upgraded again to the latest verion and it is still doing it !!!
Anyone got any ideas ??
Cheers
Matt
check the framerate of source and original
... this copy of me hasn't been registered for the last 36 years! (no spamming please) -
Ok the Divx file has a Frame rate of 23 Frames per second & Bit rate of 199Kbps.
All I can see for the SVCD file is a Bit Rate of 224Kbps,
How can I find out the Frame rate of an SVCD file ??
Anything look strange to anyone
Cheers
Matt -
23 fps isn't a framerate that's usable when makin a VCD/SVCD. (Most likely it's 23.976)
Anyway what settings did you use when encoding? That's the framerate that your SVCD has. You can check it in TMpgEnc by opening MPegTools and demulitiplex. Select your SVCD and you'll get info about the audio and video streams...
// Miko -
Ok the SVCD has 25 Frames per second, so I have found out.
So I have 2 extra frames a second in the SVCD how has this happened ?
Cheers Guys
Matt -
tmpgenc adds them
Yes, the TMPG filter duplicates the frames, that's why the playback isn't smooth. You may consider to speed up the movie from 23 to 25 fps.
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Frame-By-Frame Restored James Bond Films Released
By Soopafresh in forum RestorationReplies: 9Last Post: 27th Apr 2012, 14:09 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
