Results 1 to 15 of 15
  1. Hello, good people, need you help badly. Otherwise, I wouldn't be bothering you and would try to solve this problem on my own as I always try to do.
    Does anyone know how to download from this site Etbon? Simple one step registration with any Google account needs. There's a whole list there that I want to download:
    https://etbon.eus/m/abao-il-trovatore-es
    https://etbon.eus/m/abao-tosca-es
    https://etbon.eus/m/abao-cosi-fan-tutte-es
    https://etbon.eus/w/abao-rigoleto-es
    https://etbon.eus/w/abao-don-pasquale-es
    https://etbon.eus/w/abao-otello-es
    https://etbon.eus/w/abao-ana-bolena-es
    I download a file, but it's DRM protected and won't play—I just get a black screen with no sound. I've tried every possible program (IDM, JDownloader, XDM etc.) and browser extension. All my hopes rest on you.
    Thanks in advance.
  2. Originally Posted by Partenope View Post
    Thanks in advance.
    https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
    and
    https://forum.videohelp.com/threads/417425-Real-Device-L3-Cdms/page2#post2790373
  3. Gosh, it's a bit tricky for me Feel so silly. Any alternative ways? Without CMD etc. cause to use it I need step-by-step instructions or a very detailed video guide. But I can't find anything like that. So definitely I need something more simple. Sorry.
  4. Absolute simplicity - 'TubeDigger'.
  5. Doesn't work with this source Neither do the others from alternative list. Need something else
  6. There's not much to show - program doesn't see the video and doesn't display it in the download list, it's just empty. Countless page refreshes and opening and closing the program don't help. That's strange - usually I can find the video even by looking at the source code if programs don't work. This time nothing is working.
  7. Originally Posted by Partenope View Post
    Thanks in advance.
    hope you have python & ffmpeg already installed in your pc
    https://files.videohelp.com/u/315187/etbon.exe
    just enetr the url that has /w/ in it like
    and it will download automatically
    the website uses fixed key for all its content
    --key 662f4a9a18714d378d0cd58adcc62b16:3adcf39a811a5ab45f901e5b835b688c
    video tutorial
    https://files.videohelp.com/u/315187/Etbon-Tut.mp4
    cheers
  8. EDIT. solved. please admins, delete this message. thanks
  9. Originally Posted by xangetsue View Post
    Thanks in advance.
    video tutorial
    cheers
    xangetsue works like a charm! THANK you so much. You're a genius THAAAAAANKS!!!!!
    Jul 2026
    Spain
    Thanks in advance.
    video tutorial
    cheers
    A very good topic and very easy to understand for those of us who are not computer experts.
    I have python & ffmpeg installed in my pc but when I download with etbon.exe, the video and audio are in two separate files.
    I have two separate files in a folder: an MP4 video file (VLC) and an M4A audio file. I can only see the video without sound. What do I need to do to combine both files into a single MP4?
    I get this error ERROR: Access to the path 'C:\Users\Usuario principal\OneDrive\Mis Documentos\Documentos\temp\vascos-por-el-mundo-329-17228808\0_102_avc1.42c028_3786844_' is denied.
    What am I doing wrong, or what do I need to fix?
    Thanks in advance.
  11. Originally Posted by Hontzak View Post
    You have many options to join an audio with a video file. I use mkvtoolnix-gui.
    Jul 2026
    Spain
    Thanks for your reply.
    I know, I didn't mention it but VLC Media Player let me merge both files, but it took a long time, and I'm going to download more than 80 videos from https://etbon.eus/s/vascos-por-el-mundo. I wanted to do the whole process at once from etbon.exe if possible and if I could manage it.
    I don't know if xangetsue could help me with that.
  13. Using mkvtoonix-gui will take you 10-15 seconds per video. You have only to drop the video and audio file to "input" window and click "start multiplexing":
