I've read a lot on the site and on google searches about BIN files and I just have a question on one thing I'm not clear on.
When you burn the image to a cd as outlined here: http://www.vcdhelp.com/nerobin.htm
does the burned cd turn into a vcd after so you can go ahead and play it in your vcd player?
I was under the impression that for a VCD, you have to have an mpg to burn so in this case I'd have to convert the BIN to MPG and burn the mpg.
The bin file is an image of the disc, it can contain just about anything including mpegs. Not really an accurate analogy but think of it as a zip file. If you look at a zip file in explorer it will be one file with the extension zip. But it can contain many different types of file.
Craig
Lost Audio on kid's video project. Confused about : .HO. .adv, .HDP files?
By tmh in forum AudioReplies: 2Last Post: 7th Dec 2011, 18:50 -
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 02:02 -
confused with divx files that work
By ceve4life in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2008, 17:42
