Results 1 to 13 of 13
  1. Im trying to download from this website that gives m4s segments but not a mpd file
    init_video and init_audio file is there but ffmepg doesnt capture it
    https://prnt.sc/WKCQlV9aeA4l
    Any help,THank you
  2. Originally Posted by RKO4321 View Post
    Any help,THank you
    URL?
    in F12 DevTools Network Search: m3u8
    You can download the m3u8 file using N_m3u8dl-re.
  3. Originally Posted by sesamap159 View Post
    Any help,THank you
    URL?
    no m3u8, since the live stream is done,url doesnt work, dvtools under network only m4s segments are available seperate ,4s for video and ausio, plus init_video and init_audio, thats all
  4. Originally Posted by RKO4321 View Post
    Any help,THank you
    URL?
    Download video files in m4s format and audio files.
    import os
    import requests
    from concurrent.futures import ThreadPoolExecutor
    BASE_VIDEO_URL = "https://example.com/video/"
    BASE_AUDIO_URL = "https://example.com/audio/"
    VIDEO_DIR = "video_segments"
    AUDIO_DIR = "audio_segments"
    os.makedirs(VIDEO_DIR, exist_ok=True)
    os.makedirs(AUDIO_DIR, exist_ok=True)
    headers = {
        "User-Agent": "Mozilla/5.0"
    MAX_SEGMENTS = 1000
    def download_file(url, output_path):
        try:
            r = requests.get(url, headers=headers, timeout=15)
            if r.status_code == 200:
                with open(output_path, "wb") as f:
                    f.write(r.content)
                print(f"OK  {output_path}")
                return True
            else:
                print(f"404 {url}")
                return False
        except Exception as e:
            print(f"ERR {url} -> {e}")
            return False
    def download_video_segment(i):
        name = f"chunk_{i:05d}.m4s"
        url = BASE_VIDEO_URL + name
        path = os.path.join(VIDEO_DIR, name)
        return download_file(url, path)
    def download_audio_segment(i):
        url = BASE_AUDIO_URL + name
        path = os.path.join(AUDIO_DIR, name)
    # Télécharger init segments
    download_file(
        BASE_VIDEO_URL + "init_video.m4s",
        os.path.join(VIDEO_DIR, "init_video.m4s")
    download_file(
        BASE_AUDIO_URL + "init_audio.m4s",
        os.path.join(AUDIO_DIR, "init_audio.m4s")
    # Télécharger audio + vidéo simultanément
    with ThreadPoolExecutor(max_workers=16) as executor:
        futures = []
        for i in range(1, MAX_SEGMENTS + 1):
            futures.append(executor.submit(download_video_segment, i))
            futures.append(executor.submit(download_audio_segment, i))
        for future in futures:
            future.result()
    print("Téléchargement terminé")
    Automatic concat:
    def concat_segments(input_dir, init_name, output_file):
        with open(output_file, "wb") as outfile:
            # init segment
            with open(os.path.join(input_dir, init_name), "rb") as f:
                outfile.write(f.read())
            # chunks
            files = sorted(
                f for f in os.listdir(input_dir)
                if f.endswith(".m4s") and f != init_name
            for file in files:
                with open(os.path.join(input_dir, file), "rb") as f:
        print(f"Created {output_file}")
    concat_segments(VIDEO_DIR, "init_video.m4s", "video.mp4")
    concat_segments(AUDIO_DIR, "init_audio.m4s", "audio.m4a")
    Final merger:
    ffmpeg -i video.mp4 -i audio.m4a -c copy final.mp4
    If you can share the URL, we can download and share the video for you.
  5. Give the URL of any live stream.
  6. Problem is live stream isnt valid anymore,its from fightpass ppv, 10mins after the live stream it was chaged/deleted.
    Dec 2021
    england
    [Attachment 92312 - Click to enlarge]
    why did you message me for?
    did you message all members til you get your video
  8. Originally Posted by iamghost View Post
    I didnt ,must be a mistake
  9. Originally Posted by sesamap159 View Post
    Any help,THank you
    URL?
    import os
    import requests
    headers = {
    MAX_SEGMENTS = 1000
        try:
                    f.write(r.content)
                return True
            else:
                print(f"404 {url}")
                return False
            return False
    download_file(
    download_file(
        futures = []
            future.result()
    Automatic concat:
            # init segment
            # chunks
            files = sorted(
            for file in files:
    Final merger:
    can you please explain more how to download all the segments, please. because with ffmpeg even the init,video file not working
  10. Here is a smaple file of live stream
    https://ufcfightpass.com/live/129428
    if toy go you can clearly see the init video and audio file, how can I grab them?
    Dec 2021
    england
    It not free...
    [Attachment 92390 - Click to enlarge]
  12. Hi I got the mdp
    <?xml version="1.0" encoding="utf-8" ?>
    <!--Endeavor Streaming Server 6.6.0.20260109.40 -->
    <MPD profiles="urn:mpeg:dashrofile:isoff-live:2011" type="dynamic" availabilityStartTime="1970-01-01T00:00:00Z" publishTime="2026-05-16T23:53:09Z" minimumUpdatePeriod="PT6.006S" minBufferTime="PT6.006S" timeShiftBufferDepth="PT6H" suggestedPresentationDelay="PT18.018S" maxSegmentDuration="PT12.012S" xmlnssi="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:mpeg:dashchema:mpd:2011" xmlnscte35="urnctecte35:2014ml+bin" xmlnslink="http://www.w3.org/1999/xlink" xmlns:cenc="urn:mpeg:cenc:2013" xsichemaLocation="urn:mpegASHchema:MPD:2011 http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd">
    <Period id="264AB3563B9046E5872FD726254FE334" start="PT494156H30M28.617S">
    <AdaptationSet mimeType="video/mp4" id="0" contentType="video" minBandwidth="400000" maxBandwidth="8000000" minWidth="512" maxWidth="1920" minHeight="288" maxHeight="1080" minFrameRate="30000/1001" maxFrameRate="60000/1001" segmentAlignment="true" startWithSAP="1" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
    <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" />
    <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95" value="cenc" />
    <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed" value="cenc" />
    <InbandEventStream schemeIdUri="urnctecte35:2013ml" value="1" />
    <Accessibility schemeIdUri="urncte:dash:cc:cea-608:2015" value="CC1=eng" />
    <Role schemeIdUri="urn:mpeg:dash:role:2011" value="main" />
    <SegmentTemplate timescale="1000000" presentationTimeOffset="1778963428617677" duration="6006000" startNumber="296197707" media="media_$RepresentationID$-$Number$.m4s" initialization="init_$RepresentationID$.m4s" />
    <Representation width="960" height="540" sar="1:1" frameRate="30000/1001" codecs="avc1.4D401F" id="video_1600" bandwidth="1600000">
    <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="CE9446D3-8118-44EE-8907-B964830E2168" />
    <BaseURL>exchange300830pmprt_300830_1600/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="512" height="288" sar="1:1" frameRate="30000/1001" codecs="avc1.4D4015" id="video_400" bandwidth="400000">
    <BaseURL>exchange300830pmprt_300830_400/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="640" height="360" sar="1:1" frameRate="30000/1001" codecs="avc1.4D401E" id="video_800" bandwidth="800000">
    <BaseURL>exchange300830pmprt_300830_800/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="1280" height="720" sar="1:1" frameRate="30000/1001" codecs="avc1.4D401F" id="video_3000" bandwidth="3000000">
    <BaseURL>exchange300830pmprt_300830_3000/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="1280" height="720" sar="1:1" frameRate="30000/1001" codecs="avc1.4D401F" id="video_4500" bandwidth="4500000">
    <BaseURL>exchange300830pmprt_300830_4500/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="1280" height="720" sar="1:1" frameRate="60000/1001" codecs="avc1.4D4020" id="video_6000" bandwidth="6000000">
    <BaseURL>exchange300830pmprt_300830_6000/ijjOn2wNJ/</BaseURL>
    </Representation>
    <Representation width="1920" height="1080" sar="1:1" frameRate="60000/1001" codecs="avc1.4D402A" id="video_8000" bandwidth="8000000">
    <BaseURL>exchange300830pmprt_300830_8000/ijjOn2wNJ/</BaseURL>
    </Representation>
    </AdaptationSet>
    <AdaptationSet mimeType="audio/mp4" id="1" lang="eng" contentType="audio" segmentAlignment="true" startWithSAP="1" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
    <Label>English</Label>
    <Representation audioSamplingRate="48000" codecs="mp4a.40.2" id="audio_3000" bandwidth="128000">
    <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011" value="2" />
    </Representation>
    </AdaptationSet>
    </Period>
    <UTCTiming schemeIdUri="urn:mpeg:dash:utc:direct:2014" value="2026-05-16T23:53:04.761677Z" />
    </MPD>
    how can i get the 70p version of this, becase it always download the lowest qiality version with ffmpeg,
    Links example
    https://dice-live-us.cdnfastly.endeavorstreaming.net/1779062731_a7rtKKkGbCGepfsI_1f1b5...manifest-d.mpd
