  1. Hello,
    I have multiple ec-3 audio files only and I'm looking for fastest and small way to convert them either to ac3 or ac3 without reencoding them (is it possible?) or using too much cpu? on Linux.
    is there anything less heavy and fastest than ffmpeg?
    can it be done with any tools of bento4 ?
    I'm more interested in Fastest way and less Cpu usage than Audio quality.
    Regards
  2. Originally Posted by Karol View Post
    No, you have to re-encode it.
    ffmpeg -i input.eac3 -c ac3 -b:a 320k output.ac3
  3. Originally Posted by ProWo View Post
    I'm already using ffmpeg for that, i'm looking for alternative
    Regards
    Nov 2006
    Washington, USA
    eac3to seems to be able to extra the core AC3 5.1 from EAC3 without reencoding. From its changelog:
    v3.41
    * You can now extract the AC3 core from EAC3 with sensible syntax and no re-encoding:
    eac3to_mod in.eac3 out.ac3 -core
    If -core is omitted, re-encoding will occur.
