Hi,
Can you please help me extract the keys for this Widevine DRM?
link video : https://player.vdocipher.com/v2/?otp=20160313versUSE3231U4JmPP3rVQdDaEPGEcuC2rGa0IZ5s8...RiYmQifQ%3D%3D
PSSH:
MPD:Code:AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2NpcGhlcjo1NzYzZjQ3MTA4YTk0NWRkYjQ1ODZiYzhhMWQ3ZWRhYUjj3JWbBg==KID:Code:https://cdn03.vdocipher.com/media/6Wvk0HD0SPBT6/168e94a9/stream.mpdlicence :Code:7c10c1ed97345cf094f918c54db5962d: "usable", 8ef81023898854918c9a8b72861999fe: "usable", c02a0ad7f6f25ea78a695efe29b9d673: "usable", f1f7264ec34e5112a158f744ea7426fb: "usable",Headers:Code:https://license64.vdocipher.com/auth
thanks in advance ..HTML Code:POST https://license64.vdocipher.com/auth HTTP/2 host: license64.vdocipher.com content-length: 388 vdo-sdk: VdoWeb/2.6.11 sec-ch-ua-platform: "Windows" sec-ch-ua: "Google Chrome";v="147", "Not.A/Brand";v="8", "Chromium";v="147" sec-ch-ua-mobile: ?0 cmcd-object: ot=k user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/147.0.0.0 Safari/537.36 cmcd-session: cid="3bded3b626764b1bb08dc8a1d6c4dbbd",sf=d,sid="1b9f038067844818b7532f9191c744b4" cmcd-request: mtp=1500,su content-type: application/json accept: */* origin: https://player.vdocipher.com sec-fetch-site: same-site sec-fetch-mode: cors sec-fetch-dest: empty referer: https://player.vdocipher.com/ accept-encoding: gzip, deflate, br, zstd accept-language: fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7 priority: u=1, i
please provide direct link to video https://player.vdocipher.com/v2/?otp=xxxxxxx
Here is the URL for the video: https://www.vdocipher.com/blog/2014/12/add-text-to-videos-with-watermark/
Go to the page source code and search for encrypted-media; you will find the video URL at the top in src.
[Attachment 92108 - Click to enlarge]
My Python code, but it's in French:
I don't know why I'm getting error 403.Code:import base64 import json import re import sys from urllib.parse import urlparse, parse_qs import requests from bs4 import BeautifulSoup from pywidevine.device import Device from pywidevine.pssh import PSSH from pywidevine.cdm import Cdm # ================= CONFIG ================= WVD_PATH = "device.wvd" TIMEOUT = 10 RESET = "\033[0m" DEBUG = "\033[96m" # bleu ciel (cyan clair) INFO = "\033[93m" # jaune SUCCESS = "\033[92m" # vert KEY = "\033[94m" # bleu ERROR = "\033[91m" # rouge # ================= UTILS ================= def erreur(msg): print(f"\n{ERROR}[ERREUR] {msg}{RESET}") sys.exit(1) def requete(method, url, **kwargs): try: r = requests.request(method, url, timeout=TIMEOUT, **kwargs) r.raise_for_status() return r except requests.RequestException as e: erreur(f"{ERROR}Erreur HTTP ({url}) : {e}{RESET}") # ================= EXTRACTION TOKEN ================= def extraire_token(url): url = url.strip().replace("&", "&") try: parsed = urlparse(url) params = parse_qs(parsed.query) otp = params.get("otp", [None])[0] playback = params.get("playbackInfo", [None])[0] if not otp or not playback: raise ValueError("Paramètres manquants") return otp, playback except Exception as e: erreur(f"URL invalide : {e}") # ================= PLAYER ================= def recuperer_mpd(url): headers = {"User-Agent": "Mozilla/5.0", "Referer": url} print(f"{INFO}[INFO] Chargement du player...{RESET}") html = requete("GET", url, headers=headers).text soup = BeautifulSoup(html, "html.parser") script = soup.find("script", {"type": "application/json"}) if not script: erreur("Impossible de trouver les métadonnées (token expiré ?)") data = json.loads(script.string) try: return data["dash"]["manifest"] except KeyError: erreur("MPD introuvable dans la réponse") # ================= PSSH ================= def extraire_pssh(mpd_url): print(f"{INFO}[INFO] Récupération du MPD...{RESET}") mpd = requete("GET", mpd_url).text match = re.search(r"<cenc:pssh>(.*?)</cenc:pssh>", mpd) if not match: erreur("PSSH introuvable.") return match.group(1) def encode_license_request(data: bytes) -> str: b64 = base64.urlsafe_b64encode(data).decode() b64 = b64.replace('-', '+').replace('_', '/') return b64 def encode_token(payload: dict) -> str: raw = json.dumps(payload).encode() b64 = base64.b64encode(raw).decode() b64 = b64.replace('/', '_').replace('+', '-') return b64 # ================= DRM ================= def obtenir_cles(pssh_b64, otp, playback, url): print(f"{INFO}[INFO] Initialisation DRM...{RESET}") device = Device.load(WVD_PATH) cdm = Cdm.from_device(device) session = cdm.open() try: challenge = cdm.get_license_challenge(session, PSSH(pssh_b64)) payload = {"playbackInfo": playback, "otp": otp, "href": "https://www.vdocipher.com/", "tech": "wv", "licenseRequest": encode_license_request(challenge)} token = {"token": encode_token(payload)} headers = {"User-Agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:150.0) Gecko/20100101 Firefox/150.0", "Origin": "https://player.vdocipher.com", "Referer": "https://player.vdocipher.com/"} print(f"{INFO}[INFO] Demande de licence...{RESET}") r = requete("POST", "https://license64.vdocipher.com/auth", headers=headers, json=token) licence = base64.b64decode(r.json()["license"]) cdm.parse_license(session, licence) print(f"\n{SUCCESS}[SUCCESS] Clés récupérées :\n{RESET}") for key in cdm.get_keys(session): if key.type != "SIGNING": print(f"{KEY}[KEY] {key.kid.hex()}:{key.key.hex()}{RESET}") finally: cdm.close(session) # ================= MAIN ================= def main(): url = input(f"{DEBUG}Colle l'URL complète du player : {INFO}") otp, playback = extraire_token(url) print(f"{DEBUG}[DEBUG] OTP:{SUCCESS} {otp}{RESET}") print(f"{DEBUG}[DEBUG] PlaybackInfo:{SUCCESS} {playback}{RESET}") mpd = recuperer_mpd(url) print(f"{INFO}[INFO] MPD :{SUCCESS} {mpd}{RESET}") pssh = extraire_pssh(mpd) print(f"{INFO}[INFO] PSSH :{SUCCESS} {pssh}{RESET}") obtenir_cles(pssh, otp, playback, url) if __name__ == "__main__": main()
[Attachment 92109 - Click to enlarge] -
How to get Vdocipher key
By lucheng in forum Video Streaming DownloadingReplies: 14Last Post: 15th Feb 2026, 14:13 -
Can a Real Device L3 CDM Crack VdoCipher DRM? Seeking Advice
By iamstupidbastardok_ in forum Video Streaming DownloadingReplies: 4Last Post: 9th Dec 2025, 10:33 -
Vdocipher decryption key retrieval
By Diazole in forum Video Streaming DownloadingReplies: 101Last Post: 13th Jun 2025, 13:45 -
New vdocipher DRM
By aqzs in forum Video Streaming DownloadingReplies: 27Last Post: 2nd Apr 2025, 16:50 -
GlobalTV DRM key
By phineferb98 in forum Video Streaming DownloadingReplies: 7Last Post: 1st Apr 2024, 07:41
