I'm trying to remove duplicate frames on this source, but no matter what I do, I keep getting frame skipping.
Can anyone help me out there please, thanks!
https://drive.google.com/file/d/1eB7AdSqEnQNXBZppLKD02TA9nYq2qQnp/view?usp=sharing
Looking at the first 100 frames, I see the following as unique frames:
0 3 5 9 12 15 18 21 24 28 31 34 36 39 42 45 47 49 51 53 56 58 60 62 64 66 68 70 72 73 74 76 78 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 99
=> I do not see a pattern, the only way I see to deal with this is either:
a. either create vfr output i.e. by using DeDup (if av sync isn't required, simply don't add the time codes to the output)
b. live with duplicate frames or interpolated framesusers currently on my ignore list: deadrats, Stears555, marcorocchini -
FWIW here an attempt to temporally smoothen the video using DeDup and motion interpolation to 25fps. Not at all optimized (too lazy to try harder
How to remove duplicate frames, without any frame skipping?
By themon-master in forum RestorationReplies: 5Last Post: 8th Apr 2026, 22:21 -
mpeg2 progressive - remove duplicate frames, but no reencode?
By cinephil in forum Video ConversionReplies: 13Last Post: 27th Aug 2025, 12:13 -
Remove Duplicate Frames
By Mr. Fanservice in forum Newbie / General discussionsReplies: 3Last Post: 28th Jan 2024, 11:03 -
Remove Duplicate Images
By Jay123210599 in forum ComputerReplies: 3Last Post: 12th Jan 2024, 11:21 -
Remove dupe frames and output constant frame rate
By TenementLady in forum Video ConversionReplies: 9Last Post: 16th Aug 2023, 03:42
