After using dvd2avi and load the d2v file and wav file to TMPGEnc,
the screen shows camera symbol on all frames,
how can I get rid of the symbol ? Is is copyright protected?
thanks.,
which movie is this?
sometimes, a movie hardcodes that into the video...one way you can tell is to view the vob files w/ winDVD or powerDVD and c if the camera symbol is still there...if it is, then you've got to live w/ it -
I noticed this problem when I used to use the elecard mpeg-2 filter. had this little box in upper right hand corner. since this "watermark" is hard coded into the filter you cannot get rid of it.
since tmpgenc uses the "system" choice for mpeg-2 filter that is why you are seeing it. best thing to do is to find yourself a software dvd player, (like powerdvd) and install that. Hopefully the "system" choice will switch over to the new filter. if not you will have to hunt it down and kill it, then try reinstalling powerdvd.save the trees! recycle electrons
My TMPGEnc Authoring Works 4 in window 7
By sleung in forum Authoring (DVD)Replies: 0Last Post: 12th Sep 2011, 17:07 -
windows 7 command line problem with the % symbol
By sonic12345 in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 14:45 -
TMPGEnc Authoring Works v4 – weird warning.
By redpol in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 08:05 -
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 10:09 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 22:53
