In the above scenario, I could resize the frame or leave it as it is and add a DAR flag (which my player can read).
Does it matter which? My thinking is the DAR flag as it will cause less 'disruption' to the original file...
What do you mean, "frame"? Is the frame currently 16:9 with black side bars or do you have a 4:3 video which you want to put in a 16:9 frame?
I would strongly suggest you do not put a 4:3 video into a 16:9 frame, because if you do, when the video is viewed, either on a portrait screen eg a phone, or on a 4:3 screen in any orientation eg an ipad, the burned-in black side bars will reduce the size of the actual video.
If your video is 4:3, just leave it as-is. Almost all 16:9 players and TVs will play it properly. They will display black on the sides. -
Hi Alwyn. By "frame" I mean the dimension of the video file e.g. 960*540. Whoever created the video in question put a 4:3 picture into a 16:9 frame with no black bars which means it's 'stretched' unless I repair it.
No takers... you can set the flag with AVIDemux (which I think is using FFMPeg under the hood).
Open the file.
Set video>Copy
Set Audio>Copy
Set Output Format > MP4 Muxer
Output Format: Click Configure, then "Force" 4:3.
Save.
Check that your players respect the new flag. A test I did displays a reflagged file OK on my Android phone and my ipad, but not on my LG TV smart- TV; I had to manually set the TV display to "4:3" to make it display correctly.
My personal preference is to frame the video as it is supposed to display. Flagging, IMO, is an anachronism of the past.Last edited by Alwyn; 19th Apr 2026 at 06:53. Reason: "TV display" added for clarity.
Provided that your player(s) respect the DAR flag it has the advantage that the picture gets only resized once (at playback time).
With resizing and reencoding to 4:3, the picture gets resized 2x (means causing more 'disruption'), unless you resize it to the display's native resolution. -
Excellent info, thanks to all. In this case, I left the vid's dimensions alone and began my script with:
Code:global MeGUI_darx = 4 global MeGUI_dary = 3
Changing a bad frame to a null frame or single frame motion interpolation p
By aramkolt in forum EditingReplies: 5Last Post: 22nd Jul 2025, 20:25 -
Copying area inside frame (frame by frame) - how with avisynth?
By _Donnie in forum Video ConversionReplies: 4Last Post: 10th May 2025, 11:08 -
comparting frame to frame in edius between direct source and avisynth
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2025, 01:26 -
white full frame flicker every other frame, Mad VR 205 ok, 206 not ok
By Nicholas Steel in forum Software PlayingReplies: 1Last Post: 7th Aug 2024, 14:36 -
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27
