v6.4 released
What's new
- Source: SAC Slovak Antivirus Center -> auCDtect (~72 KB)
- Source: gyan.dev (GitHub) -> FFmpeg (~104 MB). To avoid the automatic download, you can install it manually beforehand via Command Prompt: winget install --id Gyan.FFmpeg (to update: winget upgrade --id Gyan.FFmpeg)
Results 31 to 56 of 56
New files name:
AudioFakeDetector_v6.4_All-in-One.zip
AudioFakeDetector_v6.4_Standard.zip
AudioFakeDetector_v6.4_Portable.zip -
Audio Fake Detector PRO
Truly Free Alternative
https://github.com/alessandrocomito/audiofakedetectorpro/Last edited by Goa Trance; 11th May 2026 at 03:02.
Version 7.1 released
VirusTotal
AudioFakeDetector_v7.1.exe
https://www.virustotal.com/gui/file/a3a5cd8ef48c20828d4294093ea7ac4e69f9f2adcacbcf85a4d9bb305f036098
AudioFakeDetector_v7.1_Portable.exe
https://www.virustotal.com/gui/file/dbc59e8de98b5b0404fb7c8c973b52227e2838278a4943447686c99f4753ca7cLast edited by Goa Trance; 18th May 2026 at 01:45.
[Attachment 92407 - Click to enlarge]
Could you clarify why your program interacts with Windows Defender upon executing ? -
Yes, false positive by Microsoft
If you care about Microsoft red flag, download the All-In-One non exe version and launch Start_script.cmd
Google Drive https://bit.ly/4tvBk3h -
VirusTotal
AudioFakeDetector_v7.2.exe
https://www.virustotal.com/gui/file/29e2fc91e72d5e70def4b7a4f855bc3605c4eaa9825599de9ae0e96c7900f564
AudioFakeDetector_v7.2_Portable.exe
https://www.virustotal.com/gui/file/e374a5759a68e7b5844fdda23b4dc820961543b34598fce86e095ed3b32de213Last edited by Goa Trance; 19th May 2026 at 14:43.
Version 7.6 updated 2026-05-25
AudioFakeDetector_v7.6.exe
https://www.virustotal.com/gui/file/848c3881cea072997b4166658be7f930407bc4565b130e2cfcfc73a696c8fe97
AudioFakeDetector_v7.6_Portable.exe
https://www.virustotal.com/gui/file/44ecd4c37a8789e089be585979563128b1e26066108f9470d6c9d6b871808ba7Last edited by Goa Trance; 25th May 2026 at 01:26. Reason: Version updated 2026-05-25
Version 7.7 released 2026-05-31
Added support to Hi-Res lossless; changelog inside ps1 is externalized to CHANGELOG.txt
AudioFakeDetector.exe
https://www.virustotal.com/gui/file/87a17359c9771c1262940c40952e6dc21b97cb08e3095b67b18beaa90acf7893Last edited by Goa Trance; 1st Jun 2026 at 01:26.
Updated 2026-06-04
No Microsoft false positiveLast edited by Goa Trance; 3rd Jun 2026 at 22:32.
Updated 2026-06-11
What's new
After the main analysis finishes, the script automatically rescans the target folder (including all subfolders) for audio files added during the run. Any new files found are analysed immediately with the same rules as the main pass.
The rescan repeats until no new files are found, then orphan folder cleanup runs once as usual.
No user interaction required - the process is fully automatic. Only applies when a folder is being scanned; dragging individual files is unaffected. -
Second updated 2026-06-14
Info line now shows full technical metadata: codec name, sample rate (kHz), channel count (Nch), bit depth if available (lossless only),
bitrate, duration last. Examples:
Encoder: reference libFLAC 1.3.4 │ flac │ 44.1 kHz │ 2ch │ 24 bit │ 1411 kbps │ 00:08:13
Encoder: LAME3.100 │ mp3 │ 44.1 kHz │ 2ch │ 320 kbps │ 00:04:01
Third updated 2026-06-14
Resolved a display bug in the final summary where the resume counter showed an incorrect starting file index (e.g., "10 of 9"). -
The analysis takes roughly the same time on a 1 MB file as on a 100 MB (or even larger) file because the program does not analyze the entire file.
Instead of processing the whole track second by second, the tool only takes 4-5 short "snapshots" (called slots) at specific points in the song.
You can see it clearly in this example: slot@98s → slot@176s → slot@294s → slot@372s → end@442s
Only these short segments are analyzed with the Hi-Res spectrogram (even though the track is 7 minutes and 22 seconds long).
This applies both to the length of the track (2 minutes or 2 hours makes very little difference) and to the sample rate in kHz (44.1 kHz, 96 kHz, 192 kHz).
A 192 kHz file is much larger because it contains about 4× more samples per second than a 48 kHz file.
However, since the tool only analyzes a few brief segments instead of the entire data stream, the processing time remains almost identical.
In short:
- It is not decoding and analyzing hundreds of megabytes of audio.
- It is only looking at a few scattered seconds of the track, regardless of resolution (kHz) or total duration.
- So it's not thanks to a super-fast CPU, but to the smart, efficient method the tool uses (slot-based sampling).
Result: nearly constant analysis time, whether the file is small or a huge high-resolution one.
P.S. Version 7.7 was released on 2026-06-22.Last edited by Goa Trance; 23rd Jun 2026 at 11:48.
Updated 2026-09-26
New choice menu
[1] LAC 2.0.5 + FLAD
[2] AudioAuditorCLI + FLAD
[3] FlacCompagnonCLI + FLAD -
stream detector ext failed
By whs912km in forum Video Streaming DownloadingReplies: 2Last Post: 18th Sep 2025, 02:06 -
Fake email messages
By johns0 in forum Off topicReplies: 10Last Post: 22nd Apr 2024, 13:12 -
Is there a The Stream Detector like extension for Chrome?
By Namekuseijin in forum Video Streaming DownloadingReplies: 11Last Post: 24th Apr 2023, 11:57 -
Fake Framerate???
By salvo00786 in forum Video ConversionReplies: 5Last Post: 29th Mar 2023, 16:33 -
Please beware the fake ad!!!
By moni in forum Video Streaming DownloadingReplies: 7Last Post: 16th Jun 2021, 01:22
