Hello there! I ripped Matrix, using Smartripper and DVDx. I got two VCD files, although my burning soft "Ulead Movie Maker" doesn't accept them! I know that EZCD Platinum can burn them, but I want to make Menus and Chapters. So, I wonder if I can use VCDeasy and XCHAPTOR to do the job? My doubt is because I have two VCD files, and XCHAPTOR loads all Chapter of the original movie!
Thanks!
This isn't a problem. Just follow one of Sefy's guides in the "DVD Rip" section to the left, which shows how to add chapters. Basically, for the second disk, you just need to add a "chapter offset".
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 22:43 -
trying to burn a video I made from windows movie maker onto a dvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2009, 16:02 -
Is there any way to burn a dvd that can't be copied or made into image
By yozloy in forum Authoring (DVD)Replies: 7Last Post: 17th Oct 2008, 21:54 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
