Hello guys,
I am a newbie to all this so please bear with me. I have a few vcd's that don't play right on my dvd player. I get grey images and it is constantly moving vertically. However, it does play other vcd's (spiderman, black hawk down, ali, etc...) perfectly. I have a philips dvd751 if that helps. Can someone explain to me what is wrong and how to fix the problem. Any help will be greatly appreciated.
-Edgar
can you play them fine on your computer? if they play fine, then it could be that your standalone dvd player doesn't like the brand of cd-r media you have
They all play perfectly on my pc. I used the same media for the vcd's that do work on it. Do you think it may be a region problem or something like that? Any further assitstance would be greatly appreciated. Thanks!!!
try doing a test burn on a cd-rw and c if your dvd player still has problems (it could just be a fluke w/ that particular cd-r)
Hi edgars23,
I am also quit new at all this and so i have only burned one vcd, but i have the same grey images and stripes. The strange things is that I can hear the sound perfectly, can you also hear the sound? And can you please let me know if and how you solved your problem.
Thanx
Michiel -
Some thoughts what might be wrong:
1) How do you burn the CDs? Try reducing the burning speed. Are you sure your .mpg is VCD and not SVCD, try burning as an SVCD instead.
2) PAL/NTSC? If you live in the NTSC region, your TV might have problems displaying PAL VCD. Likewise, some PAL TVs have problems with NTSC VCDs/SVCDs
3) If you have downloaded the movie, it might have corrupted during download. You can try to de-multiplex and re-multiplex the file to see if it helps. -
Hey guys,
It turned out to be my DVD PLayer. Apparently the Philips DVD-751 isn't very good on playing VCDs. I bought a Mintek 1600 player for $65 and it works like a charm. thanks for all the help in assisting me.
From,
Edgar
Problems playing 1080p files on VLC player
By Tafflad in forum Newbie / General discussionsReplies: 20Last Post: 20th Oct 2011, 16:29 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
problems playing dvd movies
By bexiga in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 19:37 -
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16
