I use VirtualDub 1.9.11 for analog capture on Windows 7. I just noticed that my Timing settings revert to defaults constantly. I read that one can use the "Save current settings as default" command but that option is missing from my Capture menu.
After selecting/checking on my timing options, I would then typically begin the capature. However, yesterday I got distracted, didn't start capture, and when I went to check the Timings screen, I disovered my settings have changed. So, now I'm wondering of my capture is being done with my prefered Timing settings.
What I tried:
- Ater setting my settings, I exited Capture Mode and closed the app. And then re-opened it. But that didn't make it remember my settings.
After setting all your settings how you want them click device settings then check save current display mode as default. That should save your settings.
If your virtualdub is acting funny or missing something for can delete the registry key and re install. Use reg edit to find the virtualdub.org registry key then delete that and then open up Virtualdub. Then save your settings. https://gist.github.com/gpoole/17b4fb3d499e3fe3719088aa34c6e401
Hi Gary. Thanks.
I deleted VirtualDub.org from the registery.
On next loading of app, I got the license screen and pressed OK.
Set my Timing settings.
Clicked Device -- Device Settings
And selected box Save curreny display mode.
I then went back to Capure -- Timing to check my settings. It was what I selected. Then I pressed OK. Then I re-opened it. I did this four times and still kept my settings, which was more than what happened yesterday.
But on the seventh try, my settings reverted to the app default (ie, sync video to audio by adjusting...).
Then I set my Timings to my preferred settings, and clicked Device -- Device Settings. And selected box Save curreny display mode. And then I exited Capture Mode.
When I re-entered capture mode and went to Capture -- Timings, my settings were once again gone. -
I don't know why you're getting inconsistent results, but the Timing settings are stored in the Windows registry. Maybe you have some antivirus software reverting it, or something..? I don't have to click anything extra to save my settings. They're pushed to the registry automatically.
"Device Settings -> Save current display mode as default" is unrelated to Timing settings. It stores your selection for Overlay vs Preview for each individual capture device.Last edited by Brad; 2nd Apr 2026 at 10:13.
My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
Issues with capture device and settings in Virtualdub
By Ad_astra in forum Capturing and VCRReplies: 3Last Post: 6th Apr 2025, 09:06 -
Panasonic DMR ES-15 How to see menu for TBC settings on VirtualDub?
By Infoman37 in forum Newbie / General discussionsReplies: 11Last Post: 31st Jan 2025, 17:57 -
VirtualDub Capture Pin Compression Settings
By DMS in forum Capturing and VCRReplies: 9Last Post: 3rd May 2024, 12:17 -
Starting VirtualDub with processing settings?
By ADeltaX in forum Newbie / General discussionsReplies: 5Last Post: 16th Dec 2022, 10:58 -
Save capture settings Virtualdub 1.9?
By hpcampr in forum Capturing and VCRReplies: 4Last Post: 7th Feb 2022, 15:40
