Results 1 to 14 of 14
    Mar 2026
    Netherlands
    I accidentally recorded some important videos with the MPEG-4 OpenCodecUnity64 codec. When playing back these files, they are unfortunately solid gray. I attempted using FFmpeg to copy video streams with re-encoding to fix these files.
    ffmpeg -i Test.mkv -c:v libx264 -c:a aac output.mkv
    This gives me a lot of errors:
    concealing 8160 DC, 8160 AC, 8160 MV errors in P frame
    [dec:mpeg4 @ 00000200a0cf01c0] corrupt decoded frame
    and with transcoding:
    ffmpeg -err_detect ignore_err -i Test3.mkv -c:v libx264 -c:a aac repaired-transcode.mp4
    with these errors popping up:
    ac-tex damaged at 36 13
    Error at MB: 1609
    P cbpy damaged at 65 13
    Any help would be greatly appreciated!
  2. Post a mediainfo report (text mode) from this mpeg-4 mkv video here.
    Mar 2026
    Netherlands
    Thanks for reaching out!
    The report:
    General
    Unique ID :
    Complete name :
    Format : Matroska
    Format version : Version 4
    File size : 23.1 MiB
    Duration : 1 min 34 s
    Overall bit rate : 2 049 kb/s
    Frame rate : 30.000 FPS
    Title : device
    Writing application : PotPlayer/26.01.14
    Writing library : Lavf62.8.102
    ErrorDetectionType : Per level 1
    Video
    Format : MPEG-4 Visual
    Format profile : Simple@L3
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : V_MPEG4/ISO/ASP
    Codec ID/Info : Advanced Simple Profile
    Duration : 1 min 28 s
    Bit rate : 1 881 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.030
    Stream size : 19.8 MiB (86%)
    Writing library : XviD 73
    Default : No
    Forced : No
    Mar 2008
    SUP is a picture style of SUBS, has to be OCR'd to get editable text.
    I'm out of idea's, see if some others will chime in
    EDIT ooops sorry,wrong thread!
  5. Try to remux the mkv to avi
    ffmpeg -i input.mkv -c copy -sn -dn output.avi
    Mar 2026
    Netherlands
    Appreciate the help! Unfortunately, that still produces a greyed out video.
  7. Originally Posted by ThomasBlok View Post
    The mediainfo seems fine.
    You cloud try to extract the raw videostream to elaborate further:
    ffmpeg -i input.mkv -vcodec copy -an -sn -dn -f rawvideo output.m4v
    Mar 2026
    Netherlands
    This produces a video that I can't open in a videoplayer. This is the mediainfo:
    Complete name :
    File size : 21.6 MiB
  9. If you upload the original not working mkv here as attachment, we could take a look.
    Mar 2026
    Netherlands
    I really appreciate the help! I attached a video recorded with the same settings of ~10 seconds.
  11. I've tried a few things with your sample video, but nothing has worked.
    What program did you use to record it?
    Can you play the file with it?
    Mar 2026
    Netherlands
    i have recorded it with PotPlayer, but these videos are also blank in this player. I have tried specifying the decoder to OpenCodecUnity64. This was giving me access violations.
  13. I'm afraid, your records are lost.
    Mar 2026
    Netherlands
    That is unfortunate, thanks for trying though!
