Hi,
the cats, however: do you know if is there some new mjpeg codec for virtualdub? or some specific mjpeg dmb1 encoder?![]()
https://www.arielnet.com/pages/show/adi-gba-01200/the-mjpeg-software-codec-guide
To be honest it is not clear to me what is your problem... if you can decode MJPEG with dmb1 fourcc by for example ffmpeg then it is regular MJPEG and nothing special...
can I encoding in MJPEG 10bit?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2025, 13:07 -
how to merge multiple avi mjpeg files?
By marcorocchini in forum Newbie / General discussionsReplies: 12Last Post: 10th Aug 2023, 09:23 -
Problem converting mjpeg format webcam footage
By JJonah in forum Video ConversionReplies: 8Last Post: 20th May 2023, 07:15 -
Using FFMPEG how can I convert a file to interlaced MJPEG?
By PRAGMA in forum Video ConversionReplies: 9Last Post: 15th Apr 2023, 11:09 -
exporting rgb images from mjpeg yuv stream
By yahuu in forum Video ConversionReplies: 1Last Post: 2nd May 2021, 02:24
