Results 1 to 13 of 13
  1. Hi I have a DVD which i want to deinterlace and convert the 29.976FPS to the original FPS. I also like to fix the aspect ratio as DVD is in 4x3 and image maybe stretched. Also like to to improve on the picture quality.
    https://www.swisstransfer.com/d/a3c7aeb0-723d-4433-8772-900758398927
  2. Some suggestions after a quick glance:
    interlaced handling: QTGMC(preset="fast") + SelectEven()
    rainbows: SSIQ
    halos: DeHalo_alpha
    chroma shift: ChromaShiftSP(X=-2.5,Y=-2.5)
    scratches&co: SpotLess adjusted by scene (maybe mask)
    additiona border fixes: after cropping BlanceBorders, i.e. "bbmod(clip, cLeft=0, cTop=8, cRight=0, cBottom=8)"
    aspect ratio: PAR signaling seems correct, seems straight forward, crop and resize to 1:1 PAR (if you want to increase resolution, keep that DAR and upscale further)
    not sure about the general
    Cu selur
  3. Just a quick shot, reverting to the proposals which you have been given in your former threads. Why don't you try and optimize yourself?
    Last edited by Sharc; 28th Mar 2026 at 03:35. Reason: Sorry, wrong file was attached, corrected
    Jan 2026
    Melbourne, Australia
    Check out VapourBox, it'll rip from DVD, auto-detect this exact scenario and set most of the parameters you need automatically. There's other filters you can also apply.
  5. Originally Posted by StuartCameronCode View Post
    Why not post an example?
  6. Thanks Selur, I cant get SSIQ & ChromaShiftSP to run on avisynth 64bit. Thanks Sharc, can you share the script please, i cant get same result as your output using avisynth.
    This is my script so far:
    v = Mpeg2Source("G:\future projects\TransferXL-00vbnTwFTX3X8L\SNAKE DEADLY ACT (Eastern Heroes)\demux\VTS_02_1.d2v", Info=3) # get video
    a = LWlibavAudioSource("G:\future projects\TransferXL-00vbnTwFTX3X8L\SNAKE DEADLY ACT (Eastern Heroes)\demux\VTS_02_1 T80 2_0ch 192Kbps DELAY 0ms.ac3") # get audio (decompressed to PCM)
    AudioDub(v, a)
    AssumeTFF()
    SRestore(frate=25)
    import("C:\Users\akuma\AviSynth+\plugins64+\spotle ss.avs")
    Crop(4,98,-8,-94) # after this cropping you have a 704x364 frame
    source = Last
    filtered = source.Spotless(ThSAD=400) # Lower ThSAD for detail preservation
    Merge(filtered, source, 0.3) # Re-injects 30% of the original grain/detail
    DeHalo_alpha(rx=1.5, ry=1.5, darkstr=1.0, brightstr=1.0)
    AssumeFPS(24.0, sync_audio=true) #slowdown if really needed
  7. SSIQ -> seems like nobody compiled it for 64bit Avisynth, you will then probably have to look for an alternative
    ChromaShiftSP => use ChromaShiftSP2 instead: https://forum.doom9.org/showthread.php?p=1851933#post1851933
  8. deleted
  9. Originally Posted by Akuma786 View Post
    As far as I remember something like
    v=LWLibavVideoSource("VTS_01_1.VOB")
    a=LWLibavAudioSource("VTS_01_1.VOB")
    audiodub(v,a)
    v.Crop(4, 100, -8, -96)
    QTGMC(preset="fast").SRestore(frate=25) #blends removal
    Spotless()
    #some denoiser here, like SMDegrain() or Temporaldegrain2() or MCDegrainSharp(), I don't remember
    assumeFPS(24,sync_audio=true)
    then encode with x264 using --sar 10/11 (assuming the player respects the -sar signalling, otherwise resize to square pixels - or whatever you think is right).
  10. deleted, double post
  11. filtered = source.Spotless(ThSAD=400) # Lower ThSAD for detail preservation
    How is this beneficial compared with using less “agressive” noise filtering settings without that “re-injection” step?
    Is there a benefit to using LWLibavVideoSource rather than MPEG2Source with a VOB input?
    Perhaps it circumvents the need to first index the file with dgindex?
    What does this do with the audio? Is there a pitch correction? Is there a risk of noticeable artifacts when going from 25FPS to 24 FPS?
    Since the audio quality seems rather low to begin with (AC3 @ 192kbps), it might be better to keep the audio track unchanged, but perhaps this would cause synchronization issues when going from 29.97FPS to 25FPS.
    By the way, small confusion regarding framerates:
    It's 30000 : 1001 = 29.97(003).
    And 24FPS is usually rendered as 24000 : 1001 = 23.976(024).
  12. Originally Posted by abolibibelot View Post
    Noise, grain, details preservation is much subject to personal preference. Easy to try out.
    LWLibav indexes the file as well and works for many formats. MPEG2Source is for mpeg2 only.
    Sampling rate gets adjusted and the pitch is affected. Pitch shift good or bad depends how it got processed before when converting from film to video (upshift <-> downshift).
    Several ways to change the framerate. For AssumeFPS(xx,sync_audio=true): Pitch is affected unless pitch correction is applied which introduces artifacts itself. For video it's just a slowdown. Frames are the same.
    Yes, unless the video is telecined/detelecined or motion interpolated which keeps the stream duration intact.
    Yes, should be 60000/1001 for NTSC fieldrate, means 30000/1001 for NTSC framerate. Film rate of 24fps gets downshifted accordingly to 24000/1001 to make it eventually NTSC broadcast compliant by telecining the film to 60000/1001 fields per second video. Blu-ray accepts 24.000 fps progressive though.
