Results 1 to 30 of 51
  1. This is the first WD drive I have bought in years and with the Seagate hard drives it has always been easy to plug this USB cable into the drive itself. With this I can't get the cable to go in the slot. I think I will beg Best Buy Canada to let me return it.
  2. I chatted with them and at first they didn't want to do anything as I opened the box. I explained how can you tell if anything is wrong with a hard drive if you don't take it out of the box. I feel awful paying all this money and I will never buy a WD hard drive again. I hope they have a remedy they said they would send an email.
    Mar 2021
    Israel
    I have many WD MyPassport drives and the cable never gave me any trouble.
    I have has issues with Seagate drives and I will never buy anything from this company ever for free.
  4. I am glad that you have good experiences with WD. I gave it another go and still the cable will not go into the drive itself. The computer end works fine but that is of no use. Perhaps it is the drive itself instead of the cable. I am sad about it but I may have to accept the loss.
    Mar 2021
    Israel
    The cable on WD My Passport has two parts I just insert the cable into the drive port according to the length and it clicks into place without any problem.
    Can you please upload an image of the cable end and the drive port?
    I am not familiar with your drive maybe it uses a different cable to WD My Passport but I doubt that.
  6. The drive port is recessed and maybe off to the side a little bit too much. Here is the drive and in the customer picture mine differs as it looks more recessed at the drive port and off a bit so the high speed cable won't connect in. So it is the hard drive not the cable. It sure would be nice if they would just take it back and even if they refunded 75 percent of the cost I think that would be alright.
    https://www.bestbuy.ca/en-ca/product/wd-easystore-5tb-usb-3-2-portable-external-hard-d...black/19407243
    https://www.youtube.com/watch?v=GBPKu6OIF7U
    The cable looks like a female to plug into a male drive port the different then in that video. It is very weird this drive I have.
    Mar 2008
    Is this the connector? It looks similar to my Seagate drive. It came with a proprietary cable, standard
    USB-A at one end and the custom male plug to fit the female socket on the drive
    Your problems nature remains unclear. Is your cable or the
    socket damaged?
  8. Thanks for your response. Yes it looks a lot like that but it is not that close to the surface it is back in and offset a bit from the look of things. As soon as I tried it the first time the cable just wouldn't go in. I think is a flaw in the manufacturing.
    Thankfully I have found some room on one of my 2 TB Seagate Hard Drives so I can stave off getting a new hard drive right away. I have a heating oil fill up coming in April and that is going to definitely lighten my wallet so it will be nice to put off getting another hard drive for maybe a month or two.
    Best Buy is suppose to get back to me within 3 to 5 business days. Hopefully being a loyal customer all these years counts for something.
  9. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    That is not a proprietary/custom cable/connector but the common Micro USB3 B cable.
    It is still used on modern external HDD/SSD's.
    You could try/test with another cable if you have it available.
    Even a Micro USB2 cable will connect/work, but of course only with USB 2 speeds.
    I have used this in situations for data recover with (partially) damaged Micro USB3 ports or when a USB2 connection was required.
    Super User: Is it safe to use a micro-USB 2 cable in a USB 3 portable hard drive?
    Yes, it's safe. The base connector is identical to the original Micro-B, only adding the USB 3.0 data send/receive lines on the side. (USB 3.0 is backwards-compatible with 2.0, and this applies equally to all connectors it introduced – both the full-size and micro-size, type-A and type-B ports).
    The end result will generally be the same as if connecting the drive to a computer's USB 2.0 port (which doesn't have these extra pins, either) – you'll be limited to the speed and power that USB 2.0 allows and won't be able to use UAS, but it should still work properly otherwise.
    The extra pins are differential signal pairs (RX+, RX-, TX+, TX-, ground). Compare pinouts for:
    USB 2.0 Type-A/B and 3.0 Type-A/B
    USB 2.0 Micro-A/B and 3.0 Micro-A/B
    The official cable & connector specification is available from USB-IF for free.
    Be sure to use a decent cable though, as magnetic disks will probably need the full 500 mA that a USB 2.0 port normally provides. Original phone cables should work fine (modern phones draw several times more anyway), but some cheap replacement cables might be unable to power the HDD at all, or it might repeatedly shut down while in use.
  10. Originally Posted by Tom Saurus View Post
    Post a pic of your port. It shold be like this
    [Attachment 91627 - Click to enlarge]
  11. Thank you all I will take a picture soon. I am just a bit tuckered out and I am going to relax a while but I will definitely get that done and uploaded to demostrate what the problem is.
  12. Originally Posted by ProWo View Post
    ^^^THIS^^^
    And that connector is very easily damaged, even the one in the picture above looks like the metal shielding has been bent, should look more a "V" in the middle..
    Rather than buying something preassembled with drive inside, you can buy a empty USB drive enclosure and them buy a better quality drive. It is well known that the quality of the drives that are put into the preassemble units is a bit on the not so prime quality..
    Here is an example which fits 2.5" laptop drives and the enclosure is only $10 US..
    https://www.amazon.com/Sabrent-Tool-free-Enclosure-Optimized-EC-UASP/dp/B00OJ3UJ2S/ref...60&sr=8-4&th=1
    That external drive case uses a USB 3 "A" to "A" cable which as a far more robust connector than what the WD external drive uses..
    Right now a INTERNAL 5 tb 2.5 inch drive is running about $190 US..
    Meanwhile a external WD 5TB drive is running $160 US..
    That is a pretty good price difference between the two, guess what suffers?
    Quality of the drive..
  13. Originally Posted by Tom Saurus View Post
    Here are the pictures but they are terrible but the best I could do with my Sister's tablet.
    Use a smartphone.
  14. Originally Posted by ProWo View Post
    Use a smartphone.
    I will give that a try. Thank you I am not the brightest bulb.
  15. The one pix with the cable end is clear enough to see that the cable end that plugs into the drive is a Micro-B USB 3.0 connector.
    Cable end that plugs into the drive looks like this..
    [Attachment 91645 - Click to enlarge]
    The other end of the cable can be USB A 3.0 or USB C 3.0. The ends are not interchangeable, only the Micro-B end will plug into the drive and that plug will only fit ONE way.
    It is claimed that a USB C 3.0 cable could plug into the USB B 3.0 side of the drive and the drive will work, I would not guarantee that is true or that it won't result in a 100% broken drive socket..
    Micro-B unlike USB C is KEYED, it only fits one way.
    USB C is not keyed and connector can be flipped..
    The Micro-B and USB "C" based USB connectors are extremely fragile, very easily broken/damaged, handle with care.
  16. Image
    [Attachment 91646 - Click to enlarge]
    [Attachment 91647 - Click to enlarge]
    [Attachment 91648 - Click to enlarge]
    [Attachment 91649 - Click to enlarge]
    These are not much better but the best I seem to be able to do. I took them with my Sister's Samsung Phone.
    The end to be connected to seems to be recessed farther than it should be and it is seems a bit skewed so it can't line up with the cable end.
    Mar 2021
    Israel
    I always buy from Amazon. They have 30 days return policy with no hassle.
    Sometimes they even pay refund without the need to return the items when the shipment cost is too high to make returning not worthwhile.
  18. My guess is you have an open box item. Someone bought it, removed the drive, stuck some old, probably bad, drive in the case, and returned it. Best Buy just looked in the box, saw a drive, put it back on the shelf, and sold it to you as a new drive.
  19. Originally Posted by Tom Saurus View Post
    Yes, you have a USB-B 3.0 connector.
    Yes, it is off centered.
    Yes, it is either a manufacturing defect OR damaged by attempting to plug connector in upside down.
    You have several options.
    1 Go back to Best buy and see if they are willing to replace the drive with the same drive as defective. Yes, if you did have data on it it will be lost, if you never got it working then no data loss. They should have offered to replace the drive immediately the first time as a measure good faith, but sadly due to folks abusing returns and stores getting scammed many often will not offer that option up front anymore.
    2 If return/replacement is not an option at all at Best Buy, then try the WD warranty return process as defective out of the box.
    You can find WD warranty info https://www.westerndigital.com/support/store/warranty-policy
    3 If WD will not replace, then you have nothing to lose by cracking open the case and see if there is a way to align the connector with the opening or grinding the opening open enough to allow the connector to pass into the case..
    There also is a chance that Best Buy was passing used/damaged returns by resealing the box but that may be difficult to prove. Many manufacturers to try to prevent this from happening by placing self adhesive seals on the opening flaps, but those seals often can be defeated by the use of a hair dryer or heat gun.
    In the future, you are better off buying computer stuff from better retailers with better return processes.. Hard to beat Amazon for returns of defective products although with Amazon, be very aware of faked products and vendors that may not be willing to use Amazon rules and return procedures.
  20. Originally Posted by Subtitles View Post
    I will see how this turns out and I am not very hopeful that they will give me a replacement drive. They seem to want people to return items to a store. It would cost me over a hundred bucks to get a ride to the nearest big City with a Best Buy store so it just isn't worth it.
    I think I definitely will start buying my hard drives from Amazon Canada and I will stick with Seagate no matter what from now and probably the 2 TB hard drives as that will be all I can afford for awhile anyway.
  21. I sure hope they make it right. I have never returned anything to Best Buy or Amazon Canada. I have been a good customer to both Companies. Thanks everyone for your advice.
  22. Originally Posted by jagabo View Post
    When I was writing my post, I forgot that some folks in this world may be "less than honest".
    I would guess that jagabo is on the right track, chances are the 5 TB drive was removed and a different old smaller than 5 TB drive was put in the case.. However when they put it back in the case, they didn't bother to put the drive and circuit board back in the case in the correct orientation which would explain the reason why the connector is offset or out of place.
    Fair chance that the 5 TB drive is gone, replaced with a cheap old small drive (far less than 5 TB) that may or may not even work. In this case, someone may have gotten a "free upgrade" in drive size (although I don't understand why someone would intentionally think that a external drive is worth this kind of hassle, manufacturers tend to put their reject (IE lower RPM or higher capacity drives that may have failed to pass QA tests at full capacity) drives in those cases and sell the unit at a discount compared to the more expensive single drives).
    Store took it back and them resold it as new to you.
    Unfortunately this puts you in a bad way as you most likely unknowingly bought a tampered with drive with no recourse.
    If this is the case, it is not WDs fault, it is the STORES fault, but they have passed the buck to you and you are left with no options.
    Even if WD warranty applies to the case serial number, they will check it over and if the drive inside is not a 5 TB drive and or the serial number on the drive does not match the serial number on the case it is game over..
  23. Originally Posted by Tom Saurus View Post
    Hi, Tom. I'm confused if you contacted WD about your drive issue, or if you're dealing with Best Buy (in Canada?). If you purchased the drive from Best Buy and they're telling you to contact WD for support on a theoretically brand-new drive, that sounds very strange to me (here in the USA, anyway). I don't shop Best Buy much, but I've bought a lot of WD drives in my time (from Amazon and from WD direct) and I have never had an issue returning a bad drive. Actually I have never had a bad WD drive right out of the box, and the few times I've had issues with a WD drive under warranty, I've not had a problem getting a refund/replacement pretty quickly.
    But if the issue is with Best Buy not allowing your return because you waited beyond 15 days to return it, I'd go back and talk to a manager and show the problem and I'll bet they'll warranty it. Or if you can't get to a nearby Best Buy store, you can (at least here in the USA) return it via mail (within a 30-day window, I think). Good luck!
  24. I feel like I shouldn't butt in, but I have to agree with ozymango on this. I mean, I sense something very strange about all this.
    Firstly, that a service support employee (if that was that person's job answering that call) --- that bit about you opened the box so all bets off; that, alone, is ripe for a complaint to a consumer affairs organization. Maybe even the government type of consumer affairs agency.
    Have you folks over there in North America lost that one-year or six-month warranty system that I remember so many years ago? That alone seems mighty weird. I thought that was sort of a standard that would be around forever?
    But that 'You opened the box. Sorry Charlie!' <- That is really, really weird!!
    Who will eventually be chosen to regulate the Internet?
  25. By the way, if there was any change of item --- old for new --- and then a supposedly new item placed back into a sales-as-new arrangement, that is the sales entity that is liable, not the person who purchased the item and discovered something wrong.
    You are dealing with a criminal offense at the retailer's end. Their job is to catch that sort of action. That's their job to have a mechanism in place to stop that from happening. The usual "mechanism" is that little plastic sticky thingy; whatever that is called.
    In fact, as I type this post I am very sure I could even find out the exact criminal code that covers that. I have years and years of that sort of research under my suspenders. We old folks no longer use belts, by the way. And that is under the criminal code, not the civil code.
  26. I have yet to hear back from Best Buy. I did an online chat with someone there and they said I would get an email from someone within 3 to 5 business days. But the longer they take to get back to me the longer it is between the time I received the hard drive and they may continue to use that against me. I didn't open the hard drive box right away I assume everything was fine and then I noticed I need to get the hard drive set up as I was running low on space on my other 4 or 5 TB drive which is a Seagate.
    The person in the chat and I should have saved the transcript as I have no record of it. They were suppose to send a survey to querie me about how satisfied I was with the chat. Well anyway the person said first "the time to return this has expired" and I fussed about that and then I pointed out I have been a long time customer and never raised any issues or returned anything in the past over the probably more than a decade I have done business with them. Then I got into describing the problem more and then they write "you opened the box and we can't do anything for you". So I fussed some more and then they wrote that someone would get back to me as they elevated the issue to a manager.
    Where it goes from here I don't know. We do have a Better Business Bureau in Canada but it would probably be the next millenia before they would do anything if they even still exist. I could raise the issue with CBC's Marketplace but whether they would take the issue up is anyone's guess.
    I am not wealthy so it will hurt taking this hit but I have many blessings in my life. I would probably be content with them letting me return this via Courier and exchanging it for a 2 TB Seagate portable USB hard drive. I am gun shy about WD hard drives now with this experience; though it this was an incident that happens often you would see it in the comments at Best Buy.
    I have never had an issue with Best Buy before. Probably the Company thinks let him take the loss and if we lose his business it doesn't matter all that much. I don't get much sense I matter much in their equation. So I will wait until Friday and see if I get an email from Best Buy and then do a chat with them. I was grateful to get through to an actual person as AI circles and rejections are maddening.
  27. Member
    Mar 2021
    Israel
    Tom, thanks for the update.
    Please keep us posted.
    I doubt if the will agree to the exchange and it is not fair to you since you paid for a 5TB and you want 2TB in return.
  28. Obviously, you should get what you paid for. Keep pressing them. They're just trying to stall you until you give up.
  29. I will have another online chat with Best Buy Canada tomorrow and see how that goes. I will tell them I will never buy another Hard Drive ever from them again unless they make this right.
