Hi.
How i can create one new profile?
I want a profile that take ALL audio of one mkv file and convert them into ac3(As channels is the source audio not only stereo).
And if i can add mkv files and check all channels the mkv file has and only these are dts convert them into ac3.
As i look at this program i don't find any that profile.
If someone knows how i can create a profile it that i ask for before please help me.
I don't know about FFmpeg Batch Converter, but if it does not allow to create custom profiles, you might be better off writing a custom script to do what you want. Although I wouldn't know how to either:
A) convert specifically all DTS audio tracks into AC3 audio, as a new MKV file, in a single step, with ffmpeg;
or B) extract all audio tracks regardless of their number or position (sometimes in MKV files the first stream with number “0” is an audio track, and the video stream is second with number “1”) and an extension matching their actual format, either with ffmpeg or with mkvextract (the problem is that both expect a specific output file name for each extracted track), then in a second step convert DTS tracks into AC3 tracks and remux them with the matching video (that part is easy). -
You can create your own when you start fresh the program or from a menu.
I figure out after i create the topic.
FFmpeg Batch AV Converter Settings Backup
By ten in forum Video ConversionReplies: 0Last Post: 22nd Dec 2025, 15:19 -
Reliable [Batch] Video Converter?
By meeshu in forum Video ConversionReplies: 8Last Post: 22nd Apr 2024, 08:38 -
FFMPEG Batch AV Converter - Name of multiplex codec
By imwellan in forum Video ConversionReplies: 4Last Post: 20th Feb 2024, 18:14 -
x265 2-pass error using FFmpeg Batch AV Converter
By pascor in forum Video ConversionReplies: 20Last Post: 19th May 2021, 08:40 -
Get the complete FFmpeg command line when using FFmpeg Batch Converter
By pascor in forum Newbie / General discussionsReplies: 8Last Post: 14th May 2021, 00:14
