    May 2017
    in time
    i made c/c++
    you need NVIDIA
    Magewell Capture Express
    it a screen capture or it support usb device capture
    [Attachment 91575 - Click to enlarge]
    c/c++ source code
    https://github.com/codeboxqc/Capture-
    x64 exe https://github.com/codeboxqc/Capture-/releases/tag/1
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Looks interesting. Is this vibe-coded?
    My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
    May 2017
    in time
    Yes
    made in 2 days!
    using deepseek to create primary structure
    and google ai studio to fix all error from deepseek
    audio is not compress 32 bit send to mkv what it get is what it save (bigger files)
    video use hvec code small
    work on my pc not test on other pc
    May 2017
    in time
    my last compilation from me
    fix some more bug and add support for more capture device
    if it work on your capture device send reply
    [Attachment 91593 - Click to enlarge]
    [Attachment 91594 - Click to enlarge]
